Largest tires on 18" wheels
AZOutlaw
My wife wants to beef up here '07. She is looking at some 18 or 20" Rockstars and wants a aggressive all terrain tire. What is the beefiest tire she can run and what would be a good size lift. If wheel spacers are needed that is fine. If you have pictures of your 18s or 20s with beefy tires and a lift post them. Thanks!
I don't know a lot about your question. I would say if you're buying rims choose rims with enough offset/backspace that you don't need spacers. Spacers as a rule suck. The Spidertrax on the T4R seem to be an exception and they work well with no reported problems but if you're buying rims save the $200 and get the correct rim.
:cheers:
BFG has the All-Terrains listed as 285/65-18. Would be equivalent of a 285/70-17 that most people use here (~33"). You will need to lift around 3/2.
I know the chassis is a different story but you may be able to get away with my size tires with less of a lift. it seems to me that the 4g can handle a larger tire. I am running a 35 inch on 18inch rims with a 5 inch lift. nitto makes mud grapplers with a lower profile off road. i like the way a 20 inch wheel looks with 33 inch tires.
peacefulpiranha
