LED LIGHT BAR INSTALL on a 2014 T4R
this might be a stupid question.
but using the high beam wire as a trigger wire, do you need to have the high beams on to turn on the led light bar? can i trigger it straight from the battery?
The trigger has to have 12V current.
So the answer to both of your questions are "yes".
This write up makes me much more willing to do the work to install the light bar I ordered! Also Couldn't find and stock style switches! You're a godsend with that link! Lol thank you!
Great Post and description!
Just bought a LED bar for my 2015 but also have been told its NOT possible to connect High Beams with bars... Could it be?
Thanks for sharing!!
Thanks!
You cannot connect them directly to the high beams, but you can use the high beam circuit as the trigger for your relay as described in my 1st post. :gossip:
Thanks [MENTION=81322]barryhiram[/MENTION]. If the grille wasn't 100% wedged in place and hopefully never coming out again, I would take it out to get some mount photos.
The concrete angle brackets I got worked perfectly with these two existing bolts in the bumper support to accommodate the 32" bar, both in height and width. I didn't have to drill or cut anything.
Was shocked at how well it worked out.
edit: Link to said brackets: http://www.lowes.com/pd/USP-2-in-x-5-187-in-Steel-Concrete-Angle/3692046
Ok guys, I'm the least handiest guy in the world, and so my crew at Best Buy is going to install my CREE bar by Opt7. Opt7 is the same company that made my LED healights, so I trust them on the light bar. Here's a link to the light bar.
C2 Series: Off-Road LED Light Bar - OPT7
So for the brackets, I saw the link to the brackets at Lowes...Those will work without any mods? I thought I saw on another thread, some fabrication shop selling brackets for $50-$60, and my thought is, why would I pay $50 when I can pay $6? Is there anything special I need to tell my Best Buy guys about these brackets? (they're not your normal Best Buy guys, they are really good. I trust them fully, and drive past like 4 other Best Buys just to get to them)
Uhhhh..... Quality of the install & and it's going to look really bad !
I can give you an example, it is a bit on the extreme side and has no direct correlation to a 5th gen 4Runner:
So someone goes and buys a quality rifle (850.00-3000.00) that is capable of shooting sub MOA at a given distance... say @ 200 yds.
Then they want to go on the cheap and they purchase a 159.95 Simmons Scope and run to Wal-Mart and pick up a set of 6.00 base and rings.
They mount said base, rings and scope, take the weapon out and shoot it and then wonder why the rifle will not shoot as capable..... I know some who have tried to do this! :wow:
Now, you, have a nice T4R, you spent $$$ 22.00 on a nice Light Bar, now you want to go out and put a 6.00 Concreted Bracket to mount that light bar instead of purchasing a quality bracket or fabricate one ! :wow::wow::wow::wow:
When you see your light bouncing around when on, you will want to re-think your choice, maybe. YMMV
See what I mean, and you are going to let Best Buy install it? What the :censored:
EDITED: Never mind, I just looked up your light bar....good luck with your project.
Heed [MENTION=103267]Saker[/MENTION] advice above.
I would save the $ on the install...get the 32" light bar, quality brackets from [MENTION=139789]RagoFabrication[/MENTION] and do the install yourself. I did the 22" of the same opt7 lightbar. Here is the write-up for for novice installers like me. I used [MENTION=103267]Saker[/MENTION]'s install as my main guide.
http://www.toyota-4runner.org/5th-gen-t4rs/222834-if-i-can-do-you-can-behind-grill-light-bar-install.html
[MENTION=103267]Saker[/MENTION] [MENTION=120701]Cymon[/MENTION]
I know guys, I know that Best Buy isn't normally good, but these guys are good, and honestly, I'm so NOT handy, seriously, it's better if they would do it. Let's just say I have trouble with IKEA furniture. I will get the [MENTION=139789]RagoFabrication[/MENTION] brackets, totally get your point, and [MENTION=103267]Saker[/MENTION], I know you were making fun of the light bar, but Opt7 is a good company. It's rate IP67 and they are CREE LEDs and they made my headlights and I have no issue with those...
Wasn't really making fun. More to the point was the bracket choice, because if your bracket moves under vibration, that isn't a good choice.
Hell, my light bar is a MicTuning bar (original eBay bar was destroyed by a well placed road rock), wasn't expensive. I thought Opt7's were close to rigid pricing until I looked.
So whatever bar works for you and gets quality results like Opt7 and my MicTuning....that's what counts.
Totally appreciate your perspective...I did spend a lot on the truck, might as well treat it right, haha. You guys have a great weekend. Waiting on my light bar and brackets.
I think you're making a good choice on the brackets. They also have a YouTube video on the install if your bestbuy guys need some background on that, as I'm sure they are comfortable with the electrical end of it.
https://m.youtube.com/watch?v=_4wmrXp5qeY
I have been really impressed so far with my Opt7. Great bang for the buck light bar.
Sometimes it's good to know one's limitations. It's your vehicle in the end and do what's right for you. Just know although we give each other a hard time in the end most on this forum are here to help when needed.
Good luck, don't hesitate to post or PM any other questions.
:cheers:
Threadjack.
I'm trying to wire an LED light to my .308, can I ground the black wire to the barrel? Will it stay sub-MOA?
72815D56-07BE-4AD8-A648-6828BF3141BD_zps2zgl5lti.jpg~original
Threadjack.
Ok, damnit [MENTION=138275]jimster716[/MENTION], the only reason I am allowing this threadjack is because of the item posted! :D
Hell yea, as long as the black wire is grounded close to the receiver end, your EBR will stay sub MOA! Been there, done that! Just don't have a photo it! :lol:
See examples of EBR's in my sig....
Teaser:
I used those concrete brackets, obviously, and have no light movement at all. They worked perfectly. Really doesn't vibrate at all, outside of what any bracket would do considering it's bolted to the bumper.
I'm completely happy with it.
Well if I only was in SLC, I'd bring it by to have you put it on...but I'll stay my unhandy ass in NC and get it put in my by my guys...
PM me a pic!
[MENTION=148344]walstylez[/MENTION]
Only one I can find right now.
Paint the brackets black and you'll barely be able to see them. They look a hell of a lot better than some hacked up aluminum stock held together by a handful of hardware, that's for sure.
charlesz
