Thanks for the kudo's, I'm glad the write-up helped!
So, you want to trigger your switch for your LED Light Bar from something that has power all the time your ignition switch is on instead of using your HB to trigger....
You will have to find a circuit to tap the trigger wire to for that to happen.
It is not hardly you will forget your switch on that powers your LED Light Bar, so you could actually run that trigger wire to the battery or another circuit that has power all the time and that will solve your request!
Hope this helps!
Thanks for the quick response. I'll do some tapping and worse case I'll put it to the battery.
