tristero
Just use normal LED bulbs (nothing fancy, no canbus stuff) and put a resistor in the rear turn signals.
If your rear bulbs are also LED, you'll need to either put two resistors per side, or one resistor with twice the resistance. But this way the resistors aren't constantly on with the front DRL bulb.
Thanks [MENTION=119582]Jeffy[/MENTION]
I'll try this out and follow up
As [MENTION=119582]Jeffy[/MENTION] recommended, try lower power LEDs that can run constantly. If you need to add resistors to prevent hyperflash, use high wattage ones and mount them on a metal surface. They will get quite warm if powered On all the time. Or go back to a standard 7443 incandescent bulb.
Yeah but the 7443 incandescent blew both sides after 2 months, replaced and got another 1 month from the bulbs and sockets. I'm on socket #3 hahaha.
I appreciate your help here, really. I'll give his method of no CANBUS and add a rear resistor.
Returning the lasfit which sucks since they are in fact very bright.
