LED turn signals
I have yet to find an LED turn signal with built-in resistors as well as one important factor...
At least from all of the LEDs I've run into when lights are on, amber is not lit. They are either not on or they are white. Amber only comes on when the turn single is activated.
I am looking for ones that still continue to light amber when the headlights are on.
lasfit switchbacks.
GTR Carbide LED 2.0 is what I’ve been using. They are on when headlights are on and flash quite bright.
Hmm... all they offer now are switch backs which are white/amber..
I have been running the LasFit switchbacks for about a month now...no hyperflash so far and love the look of the front now...
I did go with the LasFits out back and, as mentioned, are incredibly bright. I had originally gone with another GTR bulb that needed a resistor for the rears, but ultimately went with the LasFits as I didn’t like tapping into the wires.
HELP! Anyone from this great thread: I have only just started trying to replace my front turn bulbs, but when I pulled the OEM socket out and re-inserted it (just a prelim check on wire lengths and accessibility), I got the damn socket inserted and rotated about 90 degrees TOO FAR! Apparently don't know my own strength. Now it wiggles CW & CCW a few degrees, but in the wrong position and I cannot get it out! Sooo, WHAT NOW?
Should I try forcing it back Counterclockwise (about 90 degrees), against the detents that I already forced it past?
Or should I keep forcing it Clockwise (210-270 degrees), with the hope of blowing past all the other detents?
Or, should I eat crow and take it to the dealer (ouch)?
It happens at times... It would be better to go forward and let the bulb plug pop out of the socket. I feel it may get more damaged reversed,that is if it has passed the locking detents. I'm certain if the dealership gets this they will force it out and tell you it needs a new light assembly and plug socket.( $$$ for them) Just give it a twist,should just pop loose.
Thanks for the input. I can't believe how easily the bulb adapter just went in wrong and got stuck - I would have thought it would only go in right and stop where it should. On the other hand, it IS Friday the 13th! I will see if I can get a consensus on this...
