Lift and Tire Central (pics)... Post 'em Up!
Bilstein 5100 front struts and rear shocks
OME 2.5" front springs and OME 2" rear springs
Ion Alloy 183 17x8 +10 offset
Goodyear Wrangler duratrac 285/70r17
265/70/17 GY Duratracks on 17x9 ProComp wheels with -6mm offset. 3/2 ReadyLift spacers and Bilstein 5100's adjustable fronts set to stock height. I had to trim the front fender liner and remove mud flap. I like how it rides, since it's not my daily driver I really wasn't concerned but it handle ok and the tire noise isn't too maddening. The tires stick outside of the fenders with these offsets but I don't have any UCA clearance issues at all, lots of room.
265/70 17 Nitto Terra Grappler, 5100's set at 1.75, 2013 FJ's Springs. A lot of rubbing at the fender liners. I'll be moving the liners forward, setting the 5100's at 2.5 and adding rear spacers. Real happy with the overall look.
2003
18x9 1mm offset fuel mavericks
285/65r18 nitto trail grapplers.
Daystar 2.5/1.5
<a href="http://s168.photobucket.com/user/malibu7tss/media/Mobile%20Uploads/image.jpg.html" target="_blank"><img src="http://i168.photobucket.com/albums/u195/malibu7tss/Mobile%20Uploads/image.jpg" border="0" alt="4runner photo image.jpg"/></a>
Im a new member looking for any suggestions on tires. Installing daystar 2.5/1.5 on my 05 Sport V6 in week or so and then ill be ready for new tires. Thinking either cooper ATs or bfg AT size 265/70 R17.
I tried to tell you :pout: lol. Looks good, i like the wheels
Thanks for the info and advice on lift and tire size, rides and looks great!
2.5" Front Spacer
1.5" Rear Spacer
265/70R17 Rugged Terrian
Perfect set-up for Mall Crawler, I'm really happy w it
B3643688-228F-48C9-8520-2DE70259FF80-4331-000004C02C47A257_zpsc9993f35.jpg~original
A8F812D0-7C8B-458B-8C14-659F6BC9508C-4331-000004C033238943_zps61884d81.jpg~original
For giggles a pic of my off-road toy
33f635b8.jpg~original
Wheel Question
Can someone help me out with this? If im going to buy 305/70/16 Cooper STT's and obviously 16 inch wheels, what wheel width do i need? For example, there are 16x7, 16x8, and 16x10. What is the difference between these? P.S. I plan on having the bilstein coilover setup and a 1" BL. Thanks
Manufacturer approved rim width for that tire is 8-9.5. Hope that helps
Yes thank you, also would it be better in any way to get a wider or more narrow rim size?
Other than being able to run a different range of tire widths, not really any I can think of off hand. Wider wheels will allow you to run wider tires. I guess you have some weight differences and what not if you want to consider that. Also too wide could look goofy I guess.
Yeah, yeah, yeah... I know. Haha. There's so much mixed input on lift/tire size/rubbing/trimming, etc. It's tough to decide until you actually do it. I moved my liners forward and I still get a tiny bit of rubbing when I'm backing out of my driveway. Daystar 2.5/1.5 seems to be the most consistent. I'm going with coil overs soon... Now I just have to compare the pros/cons on those set ups...
Guys I have a 2.5/1.5 lift and stock 18" limited wheels. I am trying to find as tall and narrow tire as possible in an aggressive tread. I would rather not add any spacers. tirerack.com doesn't even show an AT/MT tires in a 275/65/18 tire... I am thinking I might get some steel FJ wheels and go with the pizza cutter 255/80/17 size MTs
Treaddepot.com
Go Duratrac's lots of guys have them in a 275/65/18 on here with your setup
peacefulpiranha
