Lift and Tire Central (pics)... Post 'em Up!
I really like the look of these tires. I went on the Mickey Thompson website and looked them up... I couldn't help but notice they look more like Baja STZ.
Rancho Quiklift / Spidertraxx Spacer
2008 4Runner SR5
Rancho Quiklift Coilovers Front
Rancho RS9000XL shocks Rear with Coil spacer
SpiderTraxx 1.25" spacer
265x70x17 BFG AT
Finally got my wheels and tires on. SCS SR8 17x8.5 with 285/70r17 nitto terra grapplers. Now all i need to do is build my rear bumper, rock sliders and get some coilovers.
2006 Sport V8
Hi Guys, I just bought my 2006 4Runner and looking to do a couple of things. Daystar 2.5/1.5 and 1.25 Spidertrax. Would my tires rub if I did 265/70R17 BFG ATs OR should I stick with stock 265/65R17 tires. Your expertise and comments would help greatly with this newbie. I don't really want to shave off anything to fit new tires. Plus any ideas on AT brands/size tires that would look great too. Thanks in advance!
The 265/70's will rub a little while turning with the Spidertrax, but it's an EASY fix and well worth it. It took me about 15 minutes to move the front of the fender liners forward about an inch, slice a sliver off of the inside edge of the front bumper, and to trim the "hump" out of the mud flaps. None of it was noticeable after the adjustments... except for the much improved stance!
suggestions for shocks with Cornfed Lift ?
Any Suggestions? I recently bought an 04 SR5 - V6 - 4wd, previous owner had the - Cornfed Lift: The 3" front/2" rear lift kit installed. 150K miles. It needs new shocks. I was thinking of going with the 5100 adjustable from Toytec (P/N: FJ4RBILK). I am concerned it has the 3" block in the front and the shocks only up to 2.5" on the front? I only go mild off road, mostly street, so i dont see the need to change out springs. Any suggestions?
Icon stage 1 ext travel, Camburg BJ UCAs. $60 coilover condoms to protect my $1k+ front shocks in CO winter and driving to oil drilling locations...well worth it! Used OEM BJs from a set of FJ arms with less than 5k miles on them. No longer riding on the bumpstops with 109K original suspension!!
Another lift installed!!
Lifted last weekend
LIFT KIT NYLON B FRONT 3" & REAR 2" 4-RUNNER 03-11 4WD W/ DIFF DROP
265/70/R17 Nitto Terra Grapplers
Before:
777e072a.jpg~original
After:
4df26132.jpg~original
:girl:
Added another lift and other mods..:nicethread::humble::hiding::faint:
2.5 in daystar spacer kit
Tires: 285/65/18 Nitto Trail Grappler MTs
Lift: 2.5 in Daystar spacer kit
Icon stage 1, Camburg BJ UCAs. $60 coilover condoms to protect my $1k+ front shocks in CO winter and driving to oil drilling locations...well worth it! Used OEM BJs from a set of FJ arms with less than 5k miles on them. No longer riding on the bumpstops with 109K original suspension!!
Great build!! I really like the setup.
added some rear shock boots that fit loosely around the bottom for the same reason i added the condom to the fronts. protects from ice and chemicals better than the shin guards and it was $125 cheaper!!
Hey everybody, new to the forum.
I was able to install a lift and get new tires yesterday. I'm very excited about the results, I think it turned out great.
Stock
T4RStock_zpsc48eee25.jpg~original
Daystar Lift with stock tires
T4RStockTires_zpsfd156425.jpg~original
Lift + new tires 275/70/18 I decided to go with 33's because I liked how it looked.
T4RNewTires_zpsb5525930.jpg~original
