Lift and Tire Central (pics)... Post 'em Up!
You mean with the front swaybar, or with the tires? I have LCR UCA's but was waiting for the factory UCA's to wear a bit more.
How much space do you have between here:
What setup do you have?
Tires & Wheels
35x12.5/17 BFG A/T KO2
17x8.5 Method Race Wheels - MR309 Grid Titanium w/Black Lip
Spidertrax 1.25" Hub-centric spacers
Suspension
Camburg/SAW 2.5" Coilovers
ToyTec 1/2" Top Spacer - installing today
Camburg Uniball UCAs
MaxTrac Spindles
SAW 1.5" Rear Coils w/ Daystar 1.5" Coil Spacer
Fox 2.0 Performance Series IFP LT Rear Shocks w/ Roost Shield
4Crawler 1.5" Body Lift
Prothane Sway Bar Bushings Front/Rear
MOOG Sway Bar Links
Wheeler's Off-Road Front Bumps
MetalTech 4x4 3" Extended Rear Bumps
Engine/Performance
Volant CAI w/ 5123 Pro 5 Gas Air Filter
Magnaflow Y-Pipe
PowerStop Drilled & Slotted Rotors Front & Rear
Power Stop Ceramic Pads
Dewhel JDM Billet Aluminum Battery Tie Down
Exterior
Custom Pre-Runner Front bumper by [MENTION=95421]Troymclure[/MENTION]
Baja Rack w/ Hi-Lift (NJC Neoprene Jack Cover) and Spare Tire Mount
Murder Black Badges
SS Extended Brakelines
Body Mount Chop & Folded Pinch Weld
Relentless Fab T4R Body Mount Chop Plates
Lighting
Opt7 32" LED Light Bar
(2) Opt7 LED Pods
Smoked Headlights
PIAA Extreme White Plus Low Beams
PIAA Extreme White Plus High Beams
Opt7 Interior LED Bulbs
JDM AStar LEDs (Turn Signals/Reverse/Brake)
Electronics
Pioneer DD with DVD, Navigation, Bluetooth, iPod Dock
JL Audio Speakers
Interior
Toyota All Weather Mats
McTunning Auxiliary Light Switches
Speedohealer
BlueDriver Bluetooth Professional OBDII Scan Tool
Tires & Wheels
Suspension
MaxTrac Spindles
MOOG Sway Bar Links
Engine/Performance
Magnaflow Y-Pipe
Exterior
Murder Black Badges
Lighting
(2) Opt7 LED Pods
Smoked Headlights
Electronics
JL Audio Speakers
Interior
Speedohealer
Well then.... Very nice. You are making a build thread right?!
[MENTION=142213]dinoDNA[/MENTION] to the right of the arrow, is a little polished black spot. That's where it is probably rubbing. doesn't look terrible, but if you have parts laying around. I would think it would be best to go ahead and put them on instead of waiting a bit for the stockers to wear.
[MENTION=101553]t-man[/MENTION], @ TurboProp56, [MENTION=59048]S p a r k y[/MENTION]
Thanks for all the info! I am going to pick up some zip ties on my way home from work and will be taking the exacto knife to the fender wells and bumper tonight. I think you're definitely right about the UCA contact; I will go ahead and swap those out this weekend (I picked Light Racing UCA's with the greasable joint on Amazon NIB but used for $300 bucks a few months back). Hopefully this will improve the situation, and I will report back on the findings. Fingers crossed that this eliminates the issue completely and I won't need to find a fabricator for the body chop!
-dinoDNA
On the UCA
theres that darkened area where it seems as if the inside sidewall of the tire could be rubbing against the UCA.
Finally got my new wheels and tires on! I debated for a very long time on whether to get 275s or 285s. I wanted the 285s all along but did not want to do a BMC. After tireless research and advice from forum members, I just said F it and went with the 285s.
I gotta say that I couldn't be happier and no BMC needed. The tire shop just pushed the fender liners forward and removed the front mud flaps. Thanks Carl!
Wheels are the SCS sr8 on 285/70r17 Duratracs. Bilsteins all around with front set at 2.5 and rear 1.5 daystar spacers.
Anybody have experience with Cooper STT pros? I like trail grapplers but stumbled across STTs. They look pretty good and are a lot more economical than trail grapplers.
I've been lurking this forum since I bought her. First time posting pics...
-2008 4x4 Sport V6 (original owner w/ 110,000+ miles)
-Bilstein 6112s up front (highest setting)
-Bilstein 5100s w/ SAW 1.5 springs in the back
-17 in. Matte Gunmetal FN f(x) Pro wheels
-265/65/17 Michelin's transferred over from stock wheels. I'll upsize the tires once I wear the tread out on these donuts.
Finally did a real mod over the weekend.
FN f(X) wheels
265/70/17 Nitto Terra Grapplers
Daystar 2.5/1.5 lift
My buddy has them on his FJ, put about 8000 miles on them so far, on and offroad and couldnt be happier. They still look like the day he put them on. Ive rode in the truck and its smooth and as quiet as you would want a mud tire to be. If you wanted quieter go stt maxx. Cooper is solid tires all around.
Ambrose67
