Lift and Tire Central (pics)... Post 'em Up!
You should be fine. Before I was lifted I ran General Grabber AT2s in that size and only rubbed a *tiny* bit at full lock. They're one of the larger tires so I'd think you'll be OK.
Thanks for the reply. I love the Falkens, but they appear to run larger than the others in that size.
Did a little research and it looks like the non-LT rated Falkens are the same size as the Grabbers (31.6"). The LT ones are 31.8" which I doubt would cause much of an issue. You'll hear it hitting your fender liner in parking lots at full lock but that's it.
Thanks for checking into that. Yeah I was checking out some other threads with the Falkens and they looked stuffed in others photos. Just looks much beefier than the other 265/70r's. I won't be getting tires until Spring most likely. I have stock size Grabber's on there now and they still have another 15-20K miles it looks like.
How are you liking the ride of the bigger Bilsteins? Im on the 1500s and i like them a lot. Wondering how much better bigger shocks are going to be. Thanks!
5100s Front set at 1.75, FJ Springs All Around, 1.5 Daystar spacer (rear)
Ride is much better after getting rid of the XREAS and spacer lift. I was unsure about the rear spacer, but I'm glad I kept it.
Wheels: 2018 4Runner Trail Edition
Tires: 275/70R17 BFG KO2's
Suspension: Stock Non-XREAS (OME 3" lift waiting to be installed)
Had to take a second look, thought mine was lookin extra clean for a second
The new wheels and tires look great! I am looking to pick up the same wheels in the next couple of weeks for my 04 T4R v6. I was also going to go with the K02’s but wasn’t sure hat size to go with. Have you noticed any rubbing with that size tire?
Honestly, I think 275/70/17 is the prefect fitment with these wheels. I have the tiniest bit of rubbing on the corner of square block part of the front mud flaps. Other than that I don't have anything major. I am thinking when I install the lift it will change the geometry just enough to clear that portion of the flap, if not I'll either shave it the most I can to alleviate the rubbing or just remove the flaps.
Are you running wheel spacers? If not are you rubbing on your ucas?
I’m looking at buying this same exact wheel and tire set up for my wife’s 4runner. She has the ‘16 sr5 wheels and 265/70/17 terra grappler g2s, and they look way to small but I didn’t want to have to add spidertraxx.
Click
275/70/18 Falken Wildpeak ATW3
Stock '06 Limited wheels
Bilstein 5100's front/rear set at 1.75 with FJ coils
Finished product
2.5/1.5 Daystar w/ 5th gen stock suspension
1.25” Spidertrax Wheel Spacers
285/70/17 Falken at3w
Ambrose67
