Lift and Tire Central (pics)... Post 'em Up!
2007 V6 4x4
3rd gen Tacoma springs up front & 5100’s
5th gen 4Runner springs out back & 5100’s
Thanks to all the guides and posts that helped me through this. All of you are rock stars.
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics
Hey all, here's how mine is sitting as of now.
Tires: 285/75R17 Toyo Open Country A/T III
Wheels: Method NV 305 - 17x8.5 - 0mm Offset
Spacers: Spidertrax 1.25"
Front Suspension:
Camburg UCA's
Fox 2.5 Ext. Travel Coilovers w/ DSC
Eibach 14" x 650lb Springs
Front Sway Bar Removed
Durobumps
Rear Suspension:
Fox 2.5 "Tundra Spec" Rear Shocks w/ DSC
Dobinsons C59-677V Rear Coils
Overland Custom Design Ext. Rear Sway Bar Links
Durobumps
2003 Limited 4WD
Bilstein 5100 @2.5" front; 1" coil spacer rear
17x8.5 +7 Fuel Vector
265/70/17 KO2
17x8 FN FX Pros and 265/70/17 Wildpeaks
Daystar leveling kit
Bilstein 6112s with 650# springs. JBA uca’s. Durobumps in front. Icon 2” springs, Icon 2.0 shocks and Dobinsons adjustable lower links. Toytec 2” bump stop spacer. Eimkeith pck. 1/2” diy body lift.
Ironman All Country M/T 285/70 r17 on American Racing Baja
This setup is working way better than the Toytec springs on 5100 bilsteins with the Toytec top spacer and Toytec HD Superflex rear springs.
2003 Limited 4WD
New kicks:
17x8.5 -10 Stealth Custom Series Blaze10
285/70/17 KO2
2003 T4R Sport V8
Front: 4inch Maxtrac spindle lift & SPC upper control arms
Rear: unknown, previous owner claimed he swapped the leaky hydraulic suspension for 5th gen suspension.
Had a mean front rake before I lifted it so I never touched the rear
Wheels & Tires: Ko2s 285/75/16s on 16x8 steelies
1.25” front spacers and 2” rear spacers. Spindle lift spaces about an inch.
Not the setup I wanted or what I plan on running for llong...
3" RC lift
Pro Comp 17 X 8.5's
Falken AT
I hate that the rake is still present w/ the lift however I am chalking it up to the weight of the front bumper......
New set up coming soon...
2005 V8 Sport Build begins
I have been lurking here since late 19. Finally ordered the parts for the 2005 V8 rebuild. OME 885/895 springs, OME Shocks, OME UCA's. Ditching the stock wheels for Fuel Block D752 Matte Gunmetal and 285/70R17 Wildpeak A/T3W.
Should be 2 or 3 weeks before it is all done. Waiting on the shop to schedule the work.
Thanks for all of the ideas and information. I will post before and after pics when this is done.
The original XREAS suspension is tired and needs to go away.
04 Limited V8
Bilstein 5100's
OME 886/896
JBA UCA
Kenda Klever RT KR601 35x12.5x17
Falcon Offroad T8 Seeker 17x9 -38
<a data-flickr-embed="true" href="https://www.flickr.com/photos/198028558@N05/52795598879/in/album-72177720307271002/" title="537B3522-0FC8-428A-8E8D-27581410585D"><img src="https://live.staticflickr.com/65535/52795598879_7fb5ba4d7f_z.jpg" width="640" height="427" alt="537B3522-0FC8-428A-8E8D-27581410585D"/></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
tssawlson538
