Lift installed, help needed.
Alex T4R
Install the lift and place sway bar relocators and washer spacer for radiator brakets, but the sway bar is so close to radiator bracket on the left side and on the right side there is a lot of space. I do not know if it is suppose to be like that, it is not hitting anything, i'm just afraid if i flex the suspension will it hit then, or sway bar will stay in place and not hit the radiator brackets. Below are pictures.
This is right side where there is a gap.
[/IMG]
This is the left side and the sway bar is almost flush with radiator bracket.
[/IMG]
The brackets move the sway bar down and forward, they should look like this.
Left
Right
Left
Right
They are installed the way you showed on the pictures, We were actually using your pictures and harper7 for the install, so I know it is install correctly, because it is away from coilovers. The radiator brackets are not center and maybe that why it is looking like that, but I just wanted to double check.
Thanks Billy!
P.S. Billy I checked mine and they installed exactly like in the pictures you provided.
Yeah you're good to go! After reading Mikey's post I went and looked at mine and they are the same as yours.
just for reference.. i noticed my front skid that's below the sway bar on my KDSS trail had what looked like markings from where the sway bar touched the skid edge.. i just grinded it down a little to clear it.. didn't seem like it needed much.. whether this was from the skid being banged up in there deeper or what i dunno.. if it was pushed up further towards the sway bar it didn't really look like it...
bluelinepilot
