Limited Edition Mod Thread
Which Daystar lift did you install? I'm torn between a simple 1" leveling install for the front or a 2.5/1.5. What's your take?
I bought the Daystar front and rear combo off Amazon. I really like the final result. The alignment was a little difficult but we got it real close. Any higher would require additional parts for sure.
Sent from my VS990 using Tapatalk
OK. Thanks for the info. The Daystar kit is currently in second place as I'm leaning towards the Cornfed 1" front spacer as my copilot has a difficult time climbing in now as she is 5'1". I've considered sliders / running boards but waiting until I decide on whether to perform a TRD Pro conversion for my Limited. I digress ... sorry.
Any feedback on the change in ride or handling?
I have a Daystar lift and as far as I can tell, the stock ride feeling of XREAS has been maintained. As mentioned before, the alignment was a difficult one, but they were able to get it really freaking close on the caster. If I had the $ I'd get the UCAs for peace of mind, but it still feels as though it rides the same as before.
I've also taken it off-road for the 101 course at Rausch Creek in PA. It worked exactly how I expected. Extra clearance, MINOR approach, departure and break over improvement. Obviously travel on a spacer lift is not improved, so to that degree, it was still the same as stock.
Thanks for the info. I suspected the spacers wouldn't change the suspension feel considerably.
I recently swapped my 20" Limited wheels for some SCS Stealth 6 17's and really like the added air volume. The Limited suspension felt a bit stiff to me and the wheel change seems to have helped some. I'd rather it be more plush than stiff but I'm not ready to overhaul the shocks yet. I'm installing the Cornfed front spacer for leveling on Thursday so hopefully all goes well.
I only have KO2 275/55/20 on stock LE wheels and 1.25" Spidertrax Spacers. I have a 2010-2013 T.E. Rack that I still need to install.
do the spidertrax prevent rubbing? I just got a new limited a few weeks ago and would like a similar set up if it wont lead to any headaches
