bowhun2r
Member
This is more a question on use case and budget.
Sitting in the parking lot a spacer lift and replacing the XREAS with an aftermarket lift will yield the same results.
Driving on the highway and paved local roads (roads that do not see snow) will yield similar results.
Driving on southwest PA roads or on the beach or in the woods (logging roads) will immediately tell you the difference between a spacer lift or removing the XREAS with an aftermarket full lift. And there are varying degrees of aftermarket lifts.
You can spend 500 bucks or 4K. Parking lot stance will look the same. I’ve done both and for me the spacer lift is a great look...not so much benefit for my personal needs. I want the look with a better overall driving experience regardless of where I go.
