Greenmachine86
Very nice write up
Thanks for the write up. I ordered the 4 bushings today. This is a high-impact repair IMO. Not too hard to do and makes a big difference in the overall quality of the driving experience!
Installed the new ones:
Install bolt and nut, reinstall linkage and C clip.
Reinstall into truck:
Reattach rod to transmission:
Carefully assemble the white thinga-machig to the shifter. Make sure that the rectangular portion shown in the photo earlier lays within the channel:
See this? - How does it go?
Let's find out:
It directly connected to the emergency shifter release button:
Looks like it toggles when I move the button back and forth, two positions:
Looking down into the shifter assembly I see this triangular piece of plastic. Lets set it BEHIND this piece.
Once it is set, I check for functionality:
See that white plastic cylinder? Its right above the screwdriver tip. Toggle the release button, this white cylinder should move in and out, if installed properly.
Once you confirm functionality, reinstall everything else:
How is the shifter?
Mine is tighter than a frog's arse![/COLOR][/FONT]
What an amazing detailed comical right up you rock bro off to the repair on 3 rigs I go whoot whoot
I’ve had a set of these sitting around for nearly two years now — cause I’m lazy.
Perhaps it is time...
