LTDSC Build Thread
Thanks for clarifying.
Do you happen to have a Toyota part number for the switch?
It's pictured previously with the switch.
Remember this is a momentary switch. You have to modify it as I did to become an on/off.
Sorry for crowding your build thread with questions.. But.
Do you think that your OEM switch provided different results, other than the aesthetic?
It seems that your VSC off light is the only light that comes on. But for others, lots of lights come on. Think there might be something more going on with plugging into that switch harness?
That I am unsure of. I was expecting more lights when I saw it myself but pleasantly surprised it was just the VSC off light. I don't think the OEM switch had anything to do with it. It's just a backlit wire, ground and a power wire and the tapped wire.
Interesting. I'll do this mod with a regular switch and report back. I'll use the same wires to do the grounding and illumination.
Don't want to clutter your build thread, but just wanted to congratulate you again on accomplishing the 'only vsc off light turns on when vsc off mod'
I just did it, albeit following SSt4r's method with my ecu next to the brake fluid reservoir, which by understanding shouldn't make a difference. Got both lights (diff locked and vsc off).
You have a rare bird my friend (or maybe a burnt out bulb, though I doubt it) :bravo:
Enjoy and thanks for the courage! Keep buildin
Followed the VSC mod as described here and my differential lock light does light up.
Still better than tapping into the wires by the brake fluid reservoir I suppose.
Seems as though it's random as whose diff light does or does not light up.
Thanks for the write up sir
Replaced my busted CV and took my coilovers off to get rebuilt this week. Also snuck in my super bumps while I had it apart.
I noticed a few people putting in longer bumps. Is it usually for guys that jump there rides and go over the 3" lift mark?
I've been procrastinating replacing my new OEM CVs in the boxes lately. Just hearing noises in the front that I can't pinpoint. Figured might be the stress from the trails I run and just replace even though they haven't snapped.
Is that dirt and grease just sitting around in there I see, looks like someones been slacking. LOL.
I still catch you in the morning on the 80w on occations.
with the 5100's i have and trd off road coils i have set on .85 if i was to run those bump stops would they touch all the time?
They very well might. Here's the difference in height. But these are also a lot softer than stock.
I used the spacer to space mine down because at full compression I scrub my wheel well.
And that's with my 285s. Im going up to 305 soon
Might be for more of a larger tire/rub situation. Like mine, @ 2 3/4" lift, I might touch on the stock ones on compression, but, mine doesn't leave the ground either at high speeds.
The superbumps compress to the size of the stock ones. The difference is that act like a hydraulic or air bumps to slow you down before bottoming out. Look up videos about them, they're pretty cool. I just installed mine yesterday.
im wondering if i have them spaced down too far or not. I wont know until i get my coilovers back from rebuild.
I need to flex mine out see what they look like. Haven't had time and weather isn't cooperating.
i plan to cycle my suspension before i put the coilovers back in. But i know some have put the spacers in and looking to see how big. I used older UCA washers as im not paying $5 for a spacer from wheelers.
Ya I'd get some from lowes first! Lol
Bunkstaff
