Yeah I've read your threads, cool stuff. Would you still have room in there if you raised your shock up an inch or two more? They would need to go outboard a bit to clear the wheel well. Your 12" shock is the biggest that can still have the threaded over top cap option so you are shorter by 1" than any other bypass or 3" shock. I'm debating between your short 12" smoothie, a 1" longer 2.5" bypass shock, or a 3" smoothie. And 10" or 12" on the last 2 options, I'm sure you like your 12" of travel but a 10" would be easy to fit and would I really miss that 2" of travel at the shock?(my dumb emotional side that fuels my mods says yes I would miss it).
I know they are all overkill because even my standard length RR 2.5" rears are "fine" but more travel over the rocks would be nice.
I've been thinking about welding all my own links and converting to 3-link, already plugged all my numbers into the excel calculators you can download online, should be real easy. Get rid of that driver's side upper link and potentially move the gas tank up as much as my body lift will allow.
