McMaster Carr Shoping Spree
nytefog
Member
I've got a famlily member there that get about 50% off everything, Almost anything. What should i load up on? I'm starting by build, listed below and am wondering what item i can get here to help me install and mantain. Make a list.... I might be able to get stuff for others as long as the order doesn't get too large.
I already got a kit of grade 8 bolts, shoulder bolts with metal lockers. I also orderd a buch of different sizes of rivnuts.
If you plan on adding any aftermarket lights I'd figure out which ones or at least which brand and get some security screws in that size/thread.
Maybe some grille mesh if you plan a satoshi?
There's tons of stuff that I would've ordered from there in the past but it's hard to come up with a big one time order list as it's typically things I need as I encounter problems.
edit - I'd also get parts to build some rear swaybar end links out of. I believe medic83 has the materials/sizes listed somewhere over on toyota120.com
lindwlson982
