Mechanic Recommendations
psea17
Member
Hey guys,
I"m located in the Greater Phoenix area (east valley).
Been struck with some real problematic lung issues due to C-19. Been on my back for nearly 5 weeks. Blows! I usually do all the work myself, but just feeling constantly tired & winded at the moment and really want to get a few things done on my 3rd Gen 4run while I'm down (funny, usually your vehicle is down).
I'm thinking I'll just use a mechanic. Been here since '93 and have just realized, I don't know a good mechanic! Guess that's the downside to doing your own work.
-Replacing two front CV axles which would include front diff fluid change
-Replace front wheel bearings (i just did the rear wheel bearings myself)
-Replace timing belt (idler roller, tensioner roller/hydraulic tensioner, front crankshaft seal & front camshaft seals) & all drive belts, water pump & thermostat, which would include replacing coolant (full timing belt job)
-Replace the clutch pedal bracket (easy)
-Replace fuel filter (easy)
-Install front shocks (bilsteins)
I have all the parts needed. Just looking for a few recommendations for mechanics/shops to provide the labor.
Much appreciated.
erinobr2000
