Warwicke36
I just wanted to make this post to help inform anyone who has to do head gaskets that milling the heads in my case was a non issue. I read horror stories of timing issues when searching about milling heads on the 4.0 liter motors. In my case the machine shop milled the heads .008" ... the manual states not to mill the heads and instead replace them if they are warped over .0039"
From the manual
"Maximum warpage: 0.10 mm (0.0039 in.)
If warpage is greater than maximum, replace the cylinder head."
So when the machine shop said they machined them .008" I was worried. I DID replace the timing chains with new OEM ones to combat any compounding issues with chain stretch and milled heads. My guides looked great and I think the chains were totally fine but I didn't want to risk it.
I hope this post helps anyone who is thinking about or in the middle of this process. Because when I googled milling heads 1GR-FE all I got was gloom and doom with no resolution.
From the manual
