Missing "Limited" Badge?
smkied
This is obviously a super minor thing, but our new 2011 4Runner doesn't have the "Limited" badge on the side (I'm referring to this: http://pix.cm/s/2011-06-13_10-10-39.png). Is that not standard, or did the dealer forget to put it on or what do you think? I wanted to check here before going and complaining to the dealer, since likely their first response will be "that's not standard".
P.S. Yes I am sure we bought the limited model, it has leather and big rims and all the other things the limited model should including third row :-)
Yep- comes standard with the Limited. I have a 2011 Limited and it definitely came with mine! Definitely talk to the dealer
Yep...you Canadian's don't have the badging. If you really want one, I sure there are forum member, who removed theirs, that would send you some. Also check FEEbay!
Weird I wonder why the difference. I don't care too much for it but just would be annoying if it's missing stuff :-) Like I realized I don't have an antenna in the front at all! Just a threaded hole! Do I need an antenna? Absolutely not! Am I bummed that it wasn't included for some reason? Yes! Haha :-)
I think the dealer owes you an antenna. (Even in Canada) If you do not want one, then they should provide you with a fitted cap!
I have a Canadian LTD and they do not come with the Limited emblem however they do come with an antenna.
Indeed, it should come with an antenna, though, it's not necessarily a nice one, and for about $10 you can get a replacement at Canadian tire.... http://www.toyota-4runner.org/5th-gen-t4rs/58587-ideas-shorter-antenna-14.html#post794075
E2 Rubber Replacement Mast | Canadian Tire
mib
Try checking in the "hidden" compartment behind the rear seats. They might have thrown it in there or forgot to install it. I was looking at a Tacoma before and found the antenna in a compartment similar to ours in the 4Runner.
peacefulpiranha
