Mix and Match !
calcrc
Hello all, if you have time to look at theses 2 links an let me know what you think.
Mickey Thompson Part No. 90000000130 - Mickey Thompson Baja ATZ Traditional Radial Tires
http://www.fastwheels.ca/productinfo.aspx?wn=blackout&fn=satin+black
I noticed the +20 offset, which I think might not work. Even if I take out the SpiderTrax off.
I have looked at http://www.rimsntires.com/specs.jsp and http://www.miata.net/garage/tirecalc.html and found out this size I hope I did my homework right. AH too bad it doesn t keep the numbers you put in...
Thanks in advance.
Are you lifted?
Those tires are a bit wide for an 8" wheel, look for a 9" wheel with a -12 (4.5bs) or -6 (5"bs) but either way you'll have rub issues on the bodymount with that wide of a tire.
bluelinepilot
