Jetboy
are you confident on this? i had the same problem and I used black silicon sealant around the drilled holes in the dust cap and i don't see the problem anymore. HOWEVER, weather in NC has changed too from cold (30s, 40s) to warmer weather so not sure if that is contributing to less moisture in the light.
I used this around the grommet:
Advance Auto Parts - Down for Maintenance
It's absolutely a water seal from the factory on the "dust cover". Whether it's the only water barrier I don't know without looking at the internals of the housing. It should be water tight.
