Monstaliner write-up
its holding up great! ill update with more pics when it finally stops raining here. i think I'm going to do a color change eventually, tan used to be unique and now it seems like everyone is getting a tan vehicle.
[MENTION=66039]foxrider56[/MENTION] did you replace the rubber that goes around the outside of your windows? I want to do this, but want to replace that rubber too because mines in bad shape.
I can't wait to do my truck! I would love to change colors but I think the door jams being a different color will drive me crazy. The truck is IJM, but I would love to go white.
no i did not, didn't know hot to so i just taped it
I wanted to work on mine last year with Monstaliner, but the shipping to Alaska would dang near double the price of it.... I'll hold off a bit longer to paint the lower sections of my Runner due to that...
I purchased a gallon of monstaliner. I'm in proces of taping my fenders. Where the fender flares were. Any tips on taping something that bends ? So far my best solution is little pieces of tape overlaping each other to create a curve .
Also is the mix ratio 7:1? Right ? A gallon is to much for my project but a pint was not enough and 2 pints isn't that much cheaper then a gallon.
taping it off is a pain! small pieces are your best bet for a curve. and i don't know the ratio, i used the gallon so there was no trouble with trying to figure out the ratio. sorry if I'm not any help
Finished. Waiting on it to fully cure. I sanded it with 120 grit. Hopefully that is enough. I made sure I sanded good but not to bare metal. I've noticed that where I peeled the tape of the edge isn't fully bonded to the metal. Is this normal ?
Is MEK some sort of solvent for cleaning like mineral spirits? Im going to be lining my rig soon too. I was just gonna use mineral spirits but should i use the MEK like you? Or is there a better cleaning solution?
They also make some 1/4 tape you can use. Its more flexible and comes in a vinyl option as well. The you would tape the area under that to block it off. I used it for detailing mainly, but sure it would work fine for paint as well.
https://www.amazon.com/3M-Blue-Vinyl-Tape-Inch/dp/B0089PGQJM?ie=UTF8&*Version*=1&*entries*=0
washing
I'm considering lining my roof white. Have any of you that have used Monsta seen it hold dirt any more that normal paint (because of the slight texture)?
thanks
I need to do this....I think I am only going to do the bottom 3rd of the rig. Similar to what [MENTION=99565]kolelt[/MENTION] did, but I wonder how black and black will look?
thought i would update this thread and the monstaliner is still holding up great as far as cleaning what i do is take a hose to it and get the main dirt off then take armorall on a micro fiber rag and wipe the entire body with it. cleans all dirt off it and shines it up like its new. may sound strange but it works
