19963.4lsr5
I haven’t started dropping the tank yet.
FYI. That's exactly how that body mount is supposed to be that way.loose and looking like a bushing missing.
Sent from my SM-J337V using Tapatalk
Good plan.So I think my plan is going to be removing the bad steel and rust proofing what I can and slipping the sleeve over what’s left of the frame and weld it in place. It’s 35 inches long and 1/8” thick. I’ll end up removing all the rear brake line mounts plus the gas tank spacer block bolted to the frame.
I really think it would be overkill repairing the frame and then installing that sleeve.
I’ll also run a magnet in the frame and remove all the scale that flaked off.
I will paint the inside of the sleeve with ZeroRust.
Dont waste your money in the heavy rust belt with Eastwood coatings. I dont think the internal frame can get descaled and clean enough for these products to work properly. I used that product and went into the frame a year later and it was rusting again.You work way faster than me! Have you thought about doing an internal frame coating while you've got easy access?
Something like this?
Eastwood Internal Frame Coating Aerosol Spray (14-oz.)
