My 3 point slow rebuild
Read through you're whole article. Very informative and great pictures. Thank you for taking the time to share. One little thing I'd like to mention though...
Everyone go get your favorite tube of Lubriplate.
Got it?
Now squeeze it all out and never buy it again!
Please use a high quality moly assembly lube.
I've been machining and building engines for a long time. And while lubriplate was the go to years and years ago, it has many drawbacks and can potentially ruin an engine. It is not oil soluble and can clog up small oil passages. Also, DO NOT coat the cylinders with it! It will get behind the rings, turn into heavy carbon deposits, and render the rings ineffective. On the cylinders clean, clean, clean, then wipe with oil and toilet paper until there is no more dirt. Apply just a small amount of oil to your rings to help then slide through the ring compressor. That's all you need to do for piston installation.
I finally got it running. Fired right up after I cranked it over twice. Here is the link. 3VZE First Run After Rebuild - YouTube The noises you are hearing are two different things. One, I cut off the exhaust right in front of the CAT. Secondly, I'm missing the hose for the air injection unit on the passenger exhaust manifold so it was sucking air. It runs beautifully. And surprisingly, I was only five degrees off on the timing. I have more pictures I will post later. I was just in a rush to get it running.
oil pan bolts
I know its been awhile on this post, but I'm deep into a radiator, water pump, timing belt, oil pump and cv axle replacement on a 1994 4runner 3vze, and saw your post. I'm interested in where you found the longer oil pan bolts, as I'm going to use the 2 gasket option when I start the rebuild, any info would greatly appreciated. I'm not currently doing a complete rebuild yet, but I'm anticipating it at some point, I've rebuilt several 4cyl Nissan and Toyota engines, 1st v6.:behindsofa:
delislerebecca
