My 98 Limited
Well USAA just gave me the ok that my truck is not going to be a total loss and that they will fix my truck. Apparently they were going on the vin number for the value of my truck. The USAA guy asked me if I had receipts of all my purchases toward the truck to up the value of my truck. I had receipts from 2014-2020. I have almost 150 of them that I sent to the USAA agent. [emoji23]
I did some maintenance today on my truck and my wife’s truck. Changed the oil on mines and it was a nightmare. Titus-Will Toyota changed it last and it was tight. I mean i had to use a ajustable pliers and it didn’t work. Finally i just used my punch and it came loose with 2 slight turns. I’m never letting Toyota do my oil change ever again.
Made a bracket and extension for my rack today. The brackets will be used when I have my tent on and can put an extension bar on the front of the rack to carry kayaks or anything. The H blocks are made of 6061 aluminum and the bar is made of 7075 aluminum.
So because I will only be using this brackets when camping, I choose to use grade 8 bolts to hold it together
I also made a 1 piece bracket to see which one is better. I’m liking the 1 piece.
So I moved my tire carrier to the R side instead of the middle because I’m jumping from
A 33” tire to 37”. Looks much better to me and it should of been like that from the beginning.
I have a '98 Limited too!
That 4Runner/Tacoma shotgun wedding looks great! I myself have a '98 Limited, that's just about stock though. Bilstein shock absorbers and moog springs is all she has in terms of modification.
Amazing build log!!! Subscribed to finish looking through for ideas and tips. I just got my first 98 4Runner Limited, bone stock. Working out my plans/timeline. Amazing work you've done, thanks for sharing.
Sent from my SM-G965U using Tapatalk
Well the front axle is almost done. Everything is to spec and lubed. I forgot to get the 2 c clips that go on the outer axles by the hub. Damn it’s 2:50 am. [emoji1686]
Does that torque wrench have settings for angle too? My other car has a lot of torque to yield fasteners. Gotta torque then turn so much degrees after so was considering buying a fancy wrench instead of just guesstimating
Yes it does. I bought it cuz I built a sti race block for my son a few years ago. I didn’t even know that it did that’s when I bought it from my Snap On truck. Best investment I made from my snap on tools
