My new ride 00' Limited
i had no idea you could get a limited with e-4wd and a rear e-locker!
that is a extremely rare truck!
I spent over a year looking through the awesome buyers guide and new I wanted a 99-00 Limited for the E-locker and the "AWD" (versus regular 4WD) option. I think this is what you mean? I was also considering a truck like yours 01-02 with the trac instead. I was willing to get either as long as it "felt right" if ya know what I mean...
I think that all 99-00' limiteds have this option. I will say this, thank you so much to Brian2sun for the write-up on the transmissions and different gearboxes. It makes it crystal clear on how to work the trans.
I was wondering how the button on the shifter worked, lol, its really convenient to have pushbutton awd on the fly!
Lucky...
You got a steal. Makes me wish I woulda waited a little longer and looked a little harder. I wasn't as educated about 4Runners as I am now or I would have looked for more. Love mine but I think I love yours more lol!
Long as you are under 55 you just hit the button on the shifter and your in 4wd! press it agin and your out! now I dont know were your button is but mine is on the dash, to lock the transfer case, were your rear locker button is. for that it has to be in neutral then hold the transfer case lock button down till it lights up in the dash that it is locked,of corse after you hit the 4wd button. here is the transfer case lock button
OP, nice find! Very clean looking. I paid $9500 from a private seller but that was a year and a half ago, but I didn't have to pay any ridiculous fees. I felt like I paid top end but it was super clean and it already had new upgraded shocks and the timing belt and water pump work had recently been done. I bought it for my daughter who was about to go off to school in the mountains - so the push button AWD was a plus. The e-locker is a nice to have but she'll probably never use it.
If you aren't familiar with it, read up on the "pink milkshake". If yours has the original radiator, think about replacing it. Mine was having no rad issues but I didn't want to wait until it did - so I replaced it with a new Koyo and new hoses. Also, if you don't know if the timing belt and water pump has been replaced - check into doing that - should have been done around 80-90k.
When you put a new air filter in it, pull the air box and the MAF and clean the MAF. I just had to clean my MAF due to a CEL and when I checked the service history, I found that it was done 4 years ago as well. If I had realized how easy it was to do, I would have done it before now.
Also, you can go to the website below, register, register your VIN, and see any service history that was performed at dealerships.
Service History Online - Toyota Owners
Thanks, going to check the VIN now, yeah I think I will replace the rad and install an external radiator cooler at the same time...
If you have the money get ICON vehicle dynamics new shock setup that has adjustable valve dampening control. It is not on their website yet but you can call to talk to them. You will be looking at around $2,500 but you can dial in the shocks super soft or stiff. Call and ask for Brad. These are not the exact ones but will give you a better idea of where the adjuster is located.
Dave
Picked up my 97 limited with 127k for $6400. Pretty close to new in and out and garaged. Absolutely love 3rd gens.
Sweet! It looks like the timing belt info the tech wrote on the cover was not accurate- it was done again in 09' - this is all one repair order, dealer must have hammered this owner on this one listo:
Date
Operation
Details
Payment
IL_390267 12/15/2009 TECH R/R SPARK PLUGS, PCV VALVE, TUNE UP ~|~ ~|~TECH R/R SPARK PLUGS, PCV VAL VE, FUEL FILTER, ENGINE AIR FILT ER
Parts
Name
Part #
QTY
ELEMENT SUB-ASSY, AI 1780107020 1
PLUG, SPARK 9091901192 6
VALVE SUB-ASSY, VENT 1220462010 1
FILTER ASSY, FUEL 2330062030 1
CUSTOMER PAY
BRAKE INSP 12/15/2009 PLEASE CHECK BRAKES & REPORT PLEASE CHECK BRAKES & REPORT (BR AKE LIGHT COMES ON & GOES OFF) ~|~ ~|~TECH NOTE: FRONT BRAKES 5MM, REAR SHOES HAVE 90% REMAINING.
CUSTOMER PAY
IL_390268 12/15/2009 TECH R/R TIMING BELT & WATERPUMP R/R TIMING BELT & WATERPUMP ~|~ ~|~TECH R/R TIMING BELT & WATERP UMP
Parts
Name
Part #
QTY
BELT, TIMING 1356869095 1
WATER PUMP ASSY 161006939883 1
ANTIFREEZE GALLON W 002721LLAC01 1
CUSTOMER PAY
OC1 12/15/2009 LUBE OIL FILTER/CK FLUIDS/LIGHTS LUBE OIL FILTER/CK FLUIDS/LIGHTS /WIPERS/ ~|~ ~|~TECH PERFORMED LOF & TOPPED O FF FLUIDS
Parts
Name
Part #
QTY
FILTER S/A, OIL 90915YZZG1 1
GASKET 9043012031 1
NOT AVAILABLE OIL 5
CUSTOMER PAY
FIS 12/15/2009 THROTTLE BODY SERVICE PERFORM THROTTLE BODY SERVICE ~|~ ~|~TECH PERFORMED THROTTLE BODY SERVICE
Parts
Name
Part #
QTY
THROTTLE PLATE CLEAN 002891TP00 1
CUSTOMER PAY
TRANS 12/15/2009 TRANSMISSION SERVICE PERFORM TRANSMISSION SERVICE ~|~ ~|~TECH PERFORMED TRANSMISSION S ERVICE
Parts
Name
Part #
QTY
GASKET, TRANSMISSION 3517830010 1
AUTOMATIC TRANSMISSI 00718ATF00 4
CUSTOMER PAY
TRFR 12/15/2009 TRANSFER CASE SERVICE PERFORM TRANSFER CASE SERVICE ~|~ ~|~TECH PERFORMED TRANSFER CASE SERVICE
Parts
Name
Part #
QTY
GASKET 9043018008 2
NOT AVAILABLE 75W90 3
CUSTOMER PAY
FRDIF 12/15/2009 FRONT DIFF SERVICE PERFORM FRONT DIFFERENTIAL SERVI CE ~|~ ~|~TECH PERFORMED FRONT DIFFEREN TIAL SERVICE
Parts
Name
Part #
QTY
GASKET, DRAIN PLUG 1215710010 1
GASKET 9043024003 1
CUSTOMER PAY
RRDIF 12/15/2009 REAR DIFF SERVICE PERFORM REAR DIFFERENTIAL SERVIC ~|~ ~|~TECH PERFORMED REAR DIFFERENT IAL SERVICE
Parts
Name
Part #
QTY
GASKET, DRAIN PLUG 1215710010 2
sorry for the long post- thought it would paste in smaller. All that was in 09' so at least I am definitely ok on the T-belt and diff/trans/axle fluids. I also saw a new instrument cluster 4 years ago and a new climate control/heater unit. Interesting that the first record was in 08 though...Yeah, think I lucked out on this truck....
Dave
I looked up the part numbers 57700 in the rear and 58715(extended) in the front.
Brads number at ICON is 951-689-4266
thanks, a little steep for now because I just dropped waaaay to much on new front seat, but I will use them in the future as that is perfect! Thanks
At least the history you have is good. Mine seems to be just a little over a few year period and only for problems, not maintenance, but glad to have it. I also got some paper history from the seller. And when the TB and WP were done, the date and mileage was recorded on the radiator shroud.
I've had mine for a year and a half. I got a CEL P0440 the day I drove it home and fixed by replacing the rear O2 sensor. I got a CEL P0171 last week and fixed by cleaning the MAF. Last fall, had a rear axle seal leak and the previous owner had already had all of them replaced recently. I think that is a common recurring problem with these. Replaced the radiator to hopefully avoid the pink shake. Have had to replace a few interior and exterior bulbs but other than that, it has been great. These things in this condition with low miles only get harder and harder to find.
Yeah, so far so good, but I wont be daily driving it until November when I turn my lease in...picked it up now though because you are right- tough to find. I read somewhere on here about the axle seals and to make sure the updated seal part # is used for them...
I think I will inspect the radiator and unless it looks spankin new, will replace it and install the new trans cooler. I also noticed: In between the time I looked at the truck and the time I bought it, someone removed the hitch. I am pissed because I was going to use it, but now just because they got away with it. Still it gives me an excuse to replace the bumper and install a new one with a rear tire carrier!
