Need help deciding on these Rims, Please help??
gkatmar
American Racing Thug:
what color is your vehicle, post a pic of the vehicle, that might make it easier.
Just off of the pictures you have posted, I would go with the black...
I have a black 03 4Runner. I just got an OME lift, and will be putting either BFG All Terrain tires or Goodyear M/T tires in 265/70/17.
I like the first one. I don't like the second one with the gold accents. It looks like it should be mounted on a '69 Impala :confused:
Ya I was kind of thinking that, I like the first ones as well. They have a -6 offset, will that be ok?
Ya Discount Tire said they would stick out about an 1" and I might rub. Do you think I will rub? thanks for the reply.
I know you can go out 15mm no prob. That is the difference between a 4R and an FJ wheel which members have installed. Since you have the OME, I see no major problems. Only if you upsize to tires of 285+, you may need to trim the inner fender and remove the mudguards.
I like the style of the Thugs ( 1st one ) BUT i dont know if I like the all black unless your going for the stealth look , which in that case they would look awesome ! If your not going for that look it would be nice if the inside was black and the outside was silver machined finish w/clearcoat to protect them.
