need help with brake controller
drnick
2011 4runner,installing brake controller with the wiring harness/plug that came with vehicle,I was told the harness can be hooked up to a terminal on driver side where plastic kickplate is,is this where connection be made?,and if so,how do you remove the lower driver side plastic kickplate??(i did remove the one nut near dead pedal) but I still can't get it out...I'm afraid of breaking the plastic kick plate. THX
You shouldn't need to remove any panels to get access to the plug. Its visible without removing anything (unless certain models are different).
Just crawl on the floor under the brake and gas pedal...you'll see the spot. The harness shouldv'e been in the glove box.
If you don't get it let me know, I'll take a pic and post it.
Pat
Pat
Pat,thanks,I'll try to find it,but Dealership says it's behind the plastic lower kickplate driver side,I have a 2011,should be the same as 2010?...I did get the harness in the glove box,and I have installed brake controller's on previous vehicles,but not Toyotas...pic would be appreciated...THX
Thanks Guys for the info and pics,I can't believe they hide that damn thing like that! I would have never have found it! again THX!:cowboy:
phisfunk
