And there was no oil trails under your camshaft seals?
The areas that you can see the VC gasket are right above the exhaust manifold correct?
Didn't see any oil trails anywhere.
Yep - on the VC gasket. I would think I would see fresh oil just outside of the gaskets if there was a leak, but there are areas that I can't see without taking off the plenum and other stuff. But I will be replacing the plenum gaskets when I replace the cam plugs. I will also replace the PCV valve and VC grommets when I do all of that. I hope I don't discover something else then, but I probably will.
