Need some help please
blazed870
I put an aftermarket remote start/push button start system on my 4Runner SR5. I ordered a Limited lower shroud cover to hide the keyhole. The Limited one fits great. The only problem, the Limited cover that I received from Camelback Toyota is more of a flat black and doesn't match the black that is in my SR5.
So does anyone know of a Spray Paint I can get to match?
Thanks in advance
Thanks in advance
Camelback Toyota in AZ?
Is the top cover also replaceable and just order it for the Limited? Or plastidip both of them.
Thanks in advance
What is the part # that they gave you. I'll check and see if there is another option that is the right colour.
Yes Camelback Toyota in Arizona.
The part number on the invoice is 45287-35410-C0
Here is a picture of it
There should be a number on your old one molded into the plastic
if the old SR5 number is 45287-35400 then you want a 45287-35410-C0
if the old SR5 number is 45287-60520 then you want a 45287-60530-C0
I'm not sure exactly what the difference is beyond there was a production change starting with vehicles built OCT 2010 (2011 models and newer). the one they gave you was for the 2010 model.
hope that helps.
