Need to replace exhaust due to rust 03 V6
laxstar18
So basically just as the title says, my exhaust from the cats-back needs to be replaced. Im torn between doing something like the magna flow system or just going oem. Anyone have any thoughts?
Gibson
I second the vote for Gibson. Recently put one of these on my 04 4wd v6. Couldn’t be happier, install is simple.
I replaced my 05 exhaust that rusted out with oem. I didn't really see a need to replace with aftermarket in my case.
Sent from my Pixel XL using Tapatalk
How much did that cost you? I paid around $350 for the Gibson stainless catback and I'm guessing going OEM is around that or even more expensive. Might as well make the 4Runner sound better.
Summit racing has the Gibson kit on sale now with a rebate as well until the end of June!
Sent from my iPhone using Tapatalk Pro
To be honest I am not sure as I had other work done at the same time and this was back in 2011/2012 it looks like that I replaced everything. I can try to dig out the receipts but yes I can guarantee I was higher than the Gibson. I wasn't looking to change the sound as I am happy with how it sounds. I don't need a fart cannon on the truck (not saying the Gibson is, just implying I am happy with the sound of the OEM).
How is the flange connecting the header to the catback system? I know I'm going to be replacing my system here soon but I'm worried about getting the old system off and having something to bolt the new one on to.... Mine is so rusted it looks like a solid piece which is slowly flaking away.. :(
Well considering the OEM galvanized exhaust lasted 15 years, unless your going to some kind of performance exhaust, I'd stick with OEM.
It'll probably last longer than you keep the truck.
Just two bolts, one of the flanges has threaded portions on it and if those are bad, you can just use two nuts.
Gibson 18707. I got it for less than $300 shipped, I felt it was a good deal
I can confirm that 618815 fits the 03' V8. The 6 in front refers to the stainless model, which I would recommend since you live in the rust belt, their other model is just aluminized crap. 618815 is the updated item # for 618707. There's also another model that's out there, I believe it's 618708 and that does not fit an 03', the header pipe is too short and it's probably made for an 05+.
That's exactly the reason i put oem on mine. I was originally in Philadelphia and the Northeast where everything under the vehicle rusted to crap. I live in Vegas now and over the years slowly replaced everything under there that rusted. The oem stuff lasted way longer than i expected given the circumstances do i was more than happy to put oem back on since i wasn't looking for upgraded.
new gibson
I just installed a new Gibson 618815B. I went with the Gibson stainless because I'm up in WI and heard that the Walker replacement muffler rusts easily. It was easy to install and looks great. I would recommend if you want to replace most of your exhaust.
guys with the Gibson system, do you have V6 or V8. If its the V6 hows the sound? You've all got me leaning Gibson now, though perhaps the 618815 for the side exit
Any exhaust is fine. It's the drone/ sound. Borla and magnaflow makes good stuff. If your in the area with alot of rust from salt, go stainless steel. The smaller the muffler, the louder it is. Borla is quiet but it do cost. Magnaflow is a good choice too.
Crookedcat
