New member with some questions
SpeedyG
Hey all,
I'm new to the board and new to the 4Runner world. I just bought an 89 V6 3.0 and have some Q's about it :
1- I only have a wheel lock on one side of the truck, is this normal ?
2- I'm looking for gravel guard or something like that to protect the frame, any suggestions or where can I find some ?
3- I need to do a body job on my right quarter panel and around my windshiled, any idea, suggestions on replacement, repair methods ?
4- I need a gas door, where can I get one ?
5- The side of my top (around the front windows of the top) are all rusty, any repair tips ?
More questions to come that's for sure !
Thanks !
Does anyone know how to remove this part ? (circled in red)
1) What do you mean by wheel lock? Anti-theft lug nuts, doesn't matter. If you mean manual locking hub for 2WD/4WD, there should be one on each front wheel.
3) Someone makes replacement rear quarters, try GOOGLE.
5) Someone also makes replacement window frames, try GOOGLE for a source and how to remove them (I forget how).
4) Gas door, try a junk yard
SpeedyG said:
wheel lock : the lock/free switch to use the 4X4
Can anyone tell me how the rear height sensor for the rear brake system is called ?
I need to replace my ball joints and tie rods and don't know what to go with :confused:
Thanks !!
OK, that's called a manual locking hub, not a wheel lock.
If your truck has the ADD system (may not, that may have been later than '89) it wouldn't have locking hubs at all (manual or automatic).
The previous owner must have changed one side or the other, what's on the other side?
That rear sensor is the Load Sensing Proportioning Valve (LSPV).
Any parts store should have ball joints and (I think you mean) tie rod ends (TRE's).
Thanks for all the replies ..
I still got some questions (I'll go with one for now) :
I searched the board and couldn't find a How-To on installing a fuel pump cut-off switch ... as an anti-theft
Can anyone help me on this ?
Thanks again !
Also, are any of these good : Tie Rods and Ball Joints
Thanks !!
I just bought a front end rebuild kit from that vendor and I am installing it this weekend. My experience with the seller was pretty good. They shipped promptly and even though it came from Canada the time wasn't any longer than several other items I ordered locally.
Quality looks pretty good and I'm satisfied with it. This kit will at least put everything back in good shape so it will ride better, and if I need to in a few years I can always do it again with oem parts.
For the price of the kit you can't beat it.
slacker said:
http://www.toyotafiberglass.com has the paneles you need ... even help on the replacement proceedures ..
even NEW L trims ...... like you have circled in red
check em out .
I also recommend toyotafiberglass.com. They have replacement quarter panels, fenders, L-trim, tailgates, and even hoods.
When I e-mailed Corey about US prices and shipping, he got back to me right away. Keep in mind, though, that he's a one-man operation; I asked in mid-July about rear quarters, and the waiting list is into September. So if you're looking to have them soon, better to order them now.
