New Warn Semi-Hidden Winch Kit bumpers
Fixed it....
Now it looks proper.
I thought I read somewhere that you can mount this and add the winch later. Is that true or do you basically take it completely off to install the winch?
If they had it to were you could get the winch in without taking it off or at least mostly off (MAYBE) you could remove the top mounting points and "pivot" it down but I doubt it.....I would like to shake that engineers hand.
You can put the winch in the bumper with it mounted if the front fascia is off. That’s how I installed mine.
So a few questions:
what winch did most use? I’m ordering mine at the end of the month and have bounce between warn and Smitty. VR10 or X20 looks in the debate
Cable or synthetic on the winch? I’m thinking synthetic since everything rust where I am due to snow and weather.
On plate mounting, did everyone just drill and tap the hole or is there a mount for it?
I used a Smittbilt XRC 9500. Bolted up to factory holes in bumper.
Couple things I noticed while installing:
If you have an Icon Shock Resevoir Bracket, the bumper bracket is going to overlap it and you're going to have to drill through it for the rear bracket bolt.
If you remove an additional brace, you can reinstall the plastic radiator side shrouds with minimal cutting.
Finished product.
Finished product.
Very well done sir. It looks very solid on the darker colored 4R.
Ordered mine through Summit yesterday. Also decided to grab the Cali-Raised bracket as I already have the Rago Hidden bumper bracket and Led bar and don't want to sacrifice lighting. I went with the Warn VR 10-S winch. What is everyone else running for winches?
I did the Cali-raised bracket for the behind the grill led as well. With a smittybilt X2O wireless winch.
Which light bar did you use? I am not sure if I can use a 30" or it has to be a true 32" I have the opt7 right now. I am pretty sure that will fit but I might want to change it up.
Ordered 10 mins ago along with the Smitty Gen2 X20. Total was $1218.18 shipped ($1143 w/ promo rebate). I've got some raptor liner that I plan to hit it with prior to install, love that stuff and will cover any scratches that happen during shipping.
Someone had asked about fitment with the RCI skids, I've got their full set so I'll post pics on clearance once installed.
Thanks a TON for taking the time to post all the pics and info guys, I would have shied away purely due to ignorance had you not taken the time.
That was me. I have the bumper & winch installed already & my skids are sitting in the garage waitin for some free time so I can put them on. It looks like there may be a gap between front skid & bumper. I'd be interested to know if the filler plate will work.
