Nor_cal51501's build thread
That's the plan! Well, first I'm going to enjoy the summer with the new ride and if no major problems come up, then the hunt begins again in the fall/winter.
Sweet! You'll love it.
Dang those calipers came out good. I just took a can of black spray paint and did a quick spray. You're 4runner is definitely getting hooked up lately.
FML! P0330 MIL code...well, guess I'm going to be doing knock sensors/pigtails...while
I'm in there I'm going to finally do the thermostat, and while I'm balls deep in this motor I may as well do valve cover gaskets and washers. :frusty:
Knock sensors, valve cover gaskets with special touch, thermostat and nose cone oil
Well, it's a never ending maintenance and mod list. Good thing I like wrenching on 'er. Pics to follow, but here's the beginning.
Damn, better now though than when something actually breaks or goes wrong. Seems like my maintenance list is growing everyday as well.
Dude!! I know. My motor looks like spaghetti. :crybaby::yield:
More parts on the ground than in the engine bay...well, almost. Lol
where you got the drl switch and trac switch from?
I bought the RR Diff Lock switches, pulled them apart, pulled the face off, made my own label in PS then printed it and clear coated it onto the face of the switch. Long process, but I like how it turned out so wasn't a big deal.
Cont.
Well, I'm finally getting around to putting up the pics of my maintanance this past week. Pic heavy so here it goes.
Heres my starting point
Not horrible, until you start to look up close
Oil weeping on all the edges
Drivers rear was the worst
Then I pulled off the intake manifold…
Apparently my intake manifold gasket has seen better days. Both rear water seals had a slight leak into the valley and the gasket begun to deteriorate and melt into the water port
Drivers side
And theres those pesky knock sensors
Cont.
As you can see, my PCV valve gasket has also been spewing oil everywhere
The parts just keep piling up on the ground…
Passenger side with no sludge
Drivers side with no sludge also, I was really happy to see it
Did the thermostat while I had everything torn down
New intake manifold gaskets, night and day difference between the old and new
Reassembly
Cont
Almost there
New PCV valve and gasket, also new spark plug gaskets
Annnnnd DONE!
Nice work! Now that my supercharger's on I wish I'd done more while I was in there. Go figure...
So I'm in the garage and just about to start pulling the supercharger for the...I don't know, 4th time when my local Matco buddy pulls in front of the house and says he's clearing out his inventory and selling his route. :jaw drop: So I'm over here saving money, working on my car and then this happens. :ybrick: I'm never going to get my lift kit at this rate. lol Goodby Craftsman, HELLO more Matco pieces.
Also, I found the gas leak I was having after doing the knock sensors and intake manifold gasket. The passenger rear injector had a torn upper o-ring seal. Went ahead and replaced all of them, just in case.
