Nowhere near the advertised ground clearance
Status
Not open for further replies.
Damn! Ok, thanks a lot for clearing it up. Didn't know KDSS would have such a big impact on ground clearance. Well, too late to think about it now.
Swaybar is located lower (and a larger diameter) on the KDSS TE's versus the SR5, TRD Pro and LE models not to mention the TE w/o KDSS. Bottom line: Most 4Runners have more ground clearance than KDSS equipped ones by about an inch.
This reminds me of the paradox of airing down. You lift your vehicle for more ground clearance, but by airing down you lose 1"+ from the tires sitting lower.
Ha, yes. Though you could look at it as "I put larger tires on my car so that when I air down I don't lose any of my stock clearance" :)
There is no rage settle down. It was an important factor for me that's all. It's still a beautiful machine and I'm sure I'm gonna enjoy it.
I just feel a little bit duped.
Glad it's figured out. Don't feel too bad, kdss is excellent technology handed down from the land cruisers, you've got a great vehicle. Take it easy
Following your link, I tried the 'build your own model' walkthru. With KDSS selected, the downloadable sheet still shows ground clearance as 9.6."
You might be the leading plaintiff on a class action lawsuit!!!!!!
IMO - an inch matters. At least that what my lady friend says... :)
Seriously though, if a rock is 9.5" tall, that extra inch is pretty damned important. It's the equivalent of 33 vs 35" tires. I've spent a lot of $ jumping from 35 to 39" tires for an extra 2" of ground clearance. I think it's reasonable to expect it to be close to accurate.
Meh, 8.6", 9.3", 9.5" you will be fine. While we are injecting humor......
Man who runs behind car is "Exhausted", Man who runs in front is "Tired"
Long time lurker here, decided to go ahead with the purchase of a red Trail.
As soon as I saw the car on the lot I realized it was something off with the advertised ground clearance. The specs show 9.6" but I just measured it leveled, unloaded and with the recommended tire pressure of 32psi and I get 8.6" at the skid plate. Is this just a matter of wishful thinking on behalf of Toyota or I'm missing something here.
UPDATE:
The mystery has been solved. The KDSS is reducing the ground clearance by about an inch. Thanks guys for clearing it up.
Toyota should have advertised this in the specs. I'm feeling a bit duped.
Here is an old post of mine. I agree with you the front does hang down to low.
http://www.toyota-4runner.org/5th-gen-t4rs/179419-false-advertising-ground-clearance.html
Ground clearance for a 4x2
... the advertised ground clearance. The specs show 9.6" but I just measured it leveled, unloaded and with the recommended tire pressure of 32psi and I get 8.6" at the skid plate. Is this just a matter of wishful thinking on behalf of Toyota or I'm missing something here.
UPDATE:
KDSS should not be causing a lower ground clearance. That just provides stiffer anti-sway bars and a hydraulic connection to them. It doesn't change the ride height or suspension.
The specs in the brochure indicate that the ground clearance for a 4x2 is 9" instead of 9.6". But the Trail Edition doesn't come in 2 wheel drive.
In my admittedly limited off roading i have noticed that I try to roll over any rock 6" or bigger with my TIRES. This way I am doing my level best not to test the ground clearance under the delicate bits. I figured this would be more productive than either myself or someone else walking 10' in front of the vehicle measuring rocks with a tape measure....... :hiding:
Of course I have also noticed that when I bottom something out it is normally the gas tank skid, which is MORE than 9.6" off the ground. A lot of what touches bottom has to do with the line you choose and the angles you follow over obstacles.
In my admittedly limited off roading i have noticed that I try to roll over any rock 6" or bigger with my TIRES. This way I am doing my level best not to test the ground clearance under the delicate bits. A lot of what touches bottom has to do with the line you choose and the angles you follow over obstacles.
That's exactly what [MENTION=6163]phillyd2[/MENTION] taught me the first time I was on a real trail! :bigok:
You saga of trying to get TOYOTA to buy you a new lift has just blown!!
:flame:
I think it kinda bites. Took this pic when it was less than 6 months old.
I don't understand what the big deal is. Even 8" will be fine if you are running dirt roads occasionally. I mean, my older brother did the Valley of the Gods road in a Prius. If you are running technical trails, well then, you'd be lifted (not necessarily to gain more ground clearance, but to accommodate bigger tires). And as [MENTION=105481]3wbdriver[/MENTION] said, it's a lot more about the driver's expertise at that point.
For people like [MENTION=89562]bimrunner[/MENTION] and [MENTION=3743]Jeremy[/MENTION]556 that advertised clearance might make an actual difference, but for the other 99% of us, that will never matter.
Status
TerryNap61
