2gen4runner
How do you check if a o2 sensor is bad?
Check voltage, sweep/ switching at the o2 sensor check terminal.
If you have nothing, then you have to move down the line, and start checking other things, including fuel trim.
If you have a signal, but it doesn't change when "*active tested" the sensor is likely dead.
* artificially changing fuel mix, like adding air or fuel manually
