Odd Noise. Glove compartment
Fl_tigers
Will post link to vid.me below. Please advise if that is not allowed.
https://vid.me/9qNP
Appears to be coming from the connectors in the middle of the picture. Just right of the fan.
When I touch them I feel a vibration similar to the noise I'm hearing. AC is off. Car is running.
It does not appear to be coming from the air mix servo like many other threads have pointed to. And I don't believe anything is in the fan as it happens regardless of the ac being on or off. I also tried the max temp lowest temp trick as mentioned in other threads and no difference.
This past weekend I went off roading so quite a bit of bouncing and a little mud/water. Nothing too major.
Only other thing to happen was my battery tie down fell off (thanks to the previous owners replacement not having the tie down attached to anything, something I wish I noticed before going out)
Upon a bit of further investigation the noise appears to stop when I turn off the recirculating fan. That seems to point me in the direction of something ac related. However does anyone know what those connectors are for. I can't find the diagram.
H.Sikina
