Official 3rd gen 4Runners on 35's Pic Thread
no rubing anywhere except frame at full lock.
3" toytec spacer up front
LC 7s out back
have you went off roading yet? You will rub. I even rub in the rear when I'm flexed out
Bad cellphone picture of me going hard at the gas station, but at least on im on 315's now. Got some 40% tread original MTR's to see if 35's will help me offroad as well as they help drain my gastank.
315s1.jpg~original
- What wheels are you running? Pro Comp 98 series 17"
- What is the backspacing of your wheels? 4.5"
- Do you rub the frame at full lock? No, LT arms
- Do you rub the UCA at full droop? No
- Are you running wheel spacers, if so how big are they? Only in rear 1"
- 1" body lift
BFADA977-8DE6-4557-AC0A-7E7CB3DBA3EC-1684-000001C5E6C931DA.jpg~original
- 1" body lift
how wides those tires
They are 35x12.5-17 they are a bit wider than I wanted but hey they were an extremely cheap creigslist find.
I don't see how anyone can fit 35s with NO rub with just a hammer
I have no idea how you would do it either. I'm on little bit different terms with long travel but my whole front fenders were pretty much gutted and replated to stuff mine.
What is stopping us from going to 36s? I will be getting tires sometime around May. I might try to shove 36s under it.
Not to say 36's can't fit with the right kind of modding, but our trucks struggle with 35's alone. Not to mention the wear and tare on your suspension and steering components. 35's are plenty big for these IFS trucks. Your suspension travel will be limited even more too.
What wheels are those? Are they real beadlocks?
17x8.5 Raceline Monster RT231's. Yes real beadlocks.
Same thing that keeps guys with stock jeep rubi axles from running 40's. Well most of them anyway:bash:
It has nothing to do with what you can or can't fit. With enough work you can fit whatever you want. 35's are easy to find in a street friendly tire and push the limits of the front drive train (easy to break CV's).
I think they look just rite I have the same tire/size found them on cl fo cheap to $1000 for a set of 5 only had about 2000k but mine look a little skinner but maybe its my wheels they are 7.5" wide what is yours
MaximussK
