Oil Change 5th Gen: How To- LOTS of PICS!
I bought that combo, waiting until next oil change to install. Will remove inner tube with one from the one and replace the one that it comes with.
you said "one" a little too many times to understand exactly what you are doing.
also i did read about the inner tube maybe needing to be replaced, did you get a longer one? part number? link?
The tool shown by Saker a few posts up will work if the housing does not have the metal index tab on it that the stock 5th Gen 4 Runners come with. If you use the metal oil filter housing in Sakers pic, you will be ok. I have that tool, but after a few uses find I'm not that wild about it. That's just my opinion. Many have it and think otherwise.
If you switch to the metal housing in Sakers photo, you need to transfer the longer metal tube in the original 4 Runner plastic filter housing. That metal housing was designed primarily for use in the 6 cyl 2GR-FE engine that uses a shorter 04152-YZZA1 filter.
I corrected the the crazy grammar.
Not enough coffee, I guess!
Use the OEM inner tube in the new housing.
Also, according to the Toyota tech, once that is changed, use the OEM filter replacement cartridge as normal.
how much did it cost you to make yours?
i am so sick of the wrench getting stuck on the filer housing...
and i am sick of it... Its annoying when you finish the job and have to fight with the wrench to get it off...
which has indexing grooves which will keep it from getting stuck on the plastic housing...
The billet cap with EZ Drain and socket sells for $139. Base cap is $99. It's a lifetime part design AND manufactured right here in the USA.
All the issues are eliminated. The socket will never require additional steps to remove.
I might try this. I think I get two free oil changes from my dealer, after that I'll give it a try. Fantastic job with the photos, makes it looks pretty easy.
Link please
Forgive me for not reading through the whole thread... am I going to have a hard time with the first oil change, loosening factory torques bolts/filters etc?
Forgiveness not given.
Go to first page and spend 2 minutes reading the how-to. I already spent the time and effort, all you have to do is click a button. :whipping2
Alright, yo.
I read the write-up, and it's great. So thank you.
I like to do my own oil changes, like many others on forums do. But sometimes a truck coming from the factory has things torqued down so much it makes it really unpleasant the first time you change the oil. I've had this twice where the oil filters were on so tight, I had to use the strap-and-bar type wrench that crushes the filters, and I ran into issues such as time crunches and what not because I'm not an expert mechanic with a full suite of tools.
Sometimes, it can save a headache to let the dealer mess with the first one. And who knows....even dealers can over tighten things as well.
This is what I'm trying to determine. I didn't ask where the bolts were, how to change oil, what the torque specs were... anything like that. All I wanted to know was if loosening any of the parts involved was so much of a PITA that I should consider letting the dealer do the first one, allow extra time, or do it during the daytime (I usually do them in the late evening because of time issues) when I can run to the auto parts store for something if I need it etc.
I have a geriatric dad who fell and broke his hip 5 days ago (and I don't live near him), an active 1 year old child, and I'm a rotating shift worker. I'm trying to multi task and plan ahead as best I can given life challenges at the moment.
I've read your write up. The only thing I see is the filter housing that is naturally tight when loosening. I've read through page 3 looking for what others have said or you have said about an initial oil change difficulty. I don't see anything.
I'm not a mechanic either. I thought this was a valid question. I tried a Google search and what I was looking for didn't come up. Maybe I used the wrong key words.
I'll read the rest of the pages as time allows. I probably missed it somewhere, but that happens when you can only read a page here and there.
So forgive me for breaking the cardinal rule on looking for a quick one line answer such as, "No, you should be good the first time", or, "Yeah, the first oil change is rough if you're not a good mechanic."
Cheers.
Alright, yo.
Cheers.
It isn't too bad. Just get the Pennzoil cap wrenchy doohicky and you'll be fine. The worst part for me was the fact TRD skid plate bolts have a reputation for being cross threaded from the factory and requiring some tapping to clean the threads back up. Annoying yes, but not hard to do.
http://www.oreillyauto.com/site/c/d...ck=Search_N0066_1019797_-1&pt=N0066&ppt=C0164
Pita
Now that I'm out of free oil changes I attempted my first DIY oil change on the 4Runner. I used your tutorial as a reference the entire time and it helped greatly.
After crawling under, I noticed one of the screws for the front skid was missing and one of the 12mm heads was broken off of another one. This had to have been done by Toyota during one of my free changes. Pretty disappointed they didn't take the initiative to replace them.
Once I got to the step to remove the filter housing, even with a 64mm filter wrench that thing did not come off. My dad even crawled under there to give it a shot with no luck. It was definitely torqued past spec. After grunting and groaning for a while I ended up filling up with oil and taking it to Toyota to finish the job, pleading with them not to over-torque. It was a long day but hopefully the next one will go smoothly.
Great thread! We bought a 2010 used with about 45k miles in dec 2014. We only put about 5k miles on it yearly (on road), so change oil once per year. Last Sept it went well, one skid plate bolt was already sheared off by the last Toyota dealership change. I tightened all the bolts correctly last time, but it felt like someone got under there and over torqued them after I was done when I did an oil change yesterday. All of the bolts looked heavily rusted this time. One of the oil drain cover bolt heads sheared off, so currently the cover has been left off. Not sure why the Toyota bolts under there all seem to be super rusted.
Has anyone listed the bolt part numbers for the oil change procedure? (edit) - found it:
SKID PLATE BOLT 9008011373
LOWER COVER BOLT 9010906330
I did clean them up as best as possible and put on anti-seize this time. Hopefully it helps with the next change. Been changing oil for 30 years on my own cars, I have never seen a better attempt by a manufacturer to get people into the dealer for a basic maintenance item so they can try to sell other service items. Good job Toyota.
Hey guys I'm not sure if anyone has posted anything about this filter wrench but it works great. I thought this would be a good thread to mention it.
https://www.amazon.com/Motivx-Tools...automotive&vehicleId=1&vehicleType=automotive
I was using the Assenmacher filter wrench but it always got stuck and I would have to pry it loose with a flat head screwdriver so I decided to try a different filter wrench. The Motivx works great. It slides on and off the housing without sticking.
I have the same wrench. I've only used it once, but it worked great. It was a perfect fit and as you stated, it didn't get stuck on. Sure makes the process a bit more of a pleasure.
Thank you Jeff. This is an awesome tutorial. I'm new to 4runner's and have been wondering how to do this. I get the first two changes free, however, I don't like anyone touching my truck! I'll be looking this over again and probably again. Ron.
I just changed mine at 4500 miles. Not sure I trust the dealer to do an oil change. I also put my ez drain valve on that I took off my Tacoma
Just a reminder: you do not have to remove front skid plate to change an oil filter, instead remove 4 bolts and just swing it down on hinges and work from the side. It saves a ton of time and cursing from trying to hook it back up after removal.
