littlezavasaurus
A bit confused, but are you saying it was halfway between the min mark and max mark after 5 qts? That doesn't sound too far off. It's 1.8 qts from min mark to max mark, so if you added 1.6 qts from the half way point you might be a little overfilled, ~0.7 qts or so.
Make sure you're getting a good reading too. Toyota standard is check 5 minutes after shutting off engine after warming it up. I like to pull the dipstick right after I shut off the engine and leave it out the 5 mins, allows the oil in dipstick to drain back down. Then check. Helps prevent splotchiness on the dipstick sometimes leading to a false high reading.
Yea exactly. I was concerned because it calls for 6.6 quarts but it was showing that i reached normal level after only 5. I added the 1.6 because I was too afraid of starting the engine with too little oil in it.
But its all good now, I drained some oil and put a little back in and it seems to be at the correct level now. I'm going to keep a careful eye on it the next few days and I'll definitely try your tip about keeping the dipstick out the whole 5 minutes.
