I am having trouble accessing your personal thread. Every time I try and click it , screen turns white. Just thought I would let you know. Maybe its on my end?
....What do you guys think?
I'm hesitant to try muscling that plug off and damaging the plastic housing.
You did heat up the motor good and thorough before you changed the oil right?
Thanks for the quick reply!
I did, followed Antman's instructions. I'll head out and see if I can find a strap-wrench or something that I can put around the filter housing. With it being plastic I don't want to damage it trying to loosen the plug.
Got it!!! Got a strap-wrench from ACE and while sweating bullets and cursing the dude who put it on last time, or God knows how long it has been like that and they just keep putting it back like that, I managed to get it off without damaging the plastic canister.
Thank you again for the quick response man, much appreciated!!!!
That's why I do all my own servicing. No excuse for that.
I would fix it now while you have it off. If he got it on that tight, you aren't going to screw anything by undoing what he did. Hopefully he didn't screw up the threads.
The reason I say fix it now is that it makes the oil changes a lot less messy.
many years ago I used only the strap wrench did not mess with the filter housing drain plug since I had a large drain pan. those housings then were made of metal.
good you got the drain plug out with out damaging the plastic housing.
my guess is the lube jockeys over torque all this stuff because they do not replace the O rings and gasket washers.
with the use of the strap wrench which I seldom use much now I, used to use 80 grit sand paper with the adhesive backing ,,, cut the sand paper in a strip placed on oil filter , then put strap wrench over the sand paper never had any slippage.. this is usually on the first OEM/dealership oil change.
I use sockets now , on all these items but it can happen when I get out that strap wrench.
Gently insert the bleeder drain valve that comes with the new filter, but don't press it up yet. Then take an empty 20oz coke bottle, put the neck over the edges of the drain valve device and push up. The oil drains into the bottle and you've actuated the valve. Once empty after about a minute, take your rag and remove the insert.
Hope this helps you in your next oil change.
I can only tell you my experience, which leads me to tell you it does not.Does the truck need to be level when draining the oil? I want to use ramps to make it easier.
I used jack stands in the front on my 1st oil change. I figured I should lift the rear higher than the front to drain the rest of the residual oil. After messing around moving the jack stands to the back and then dropping the front lower, nothing came out. I wasted about 15 minutes doing that and had no result.
Therefore, I would say no based on my one time experience, no, but I would be curious to hear if others have had a different experience.
Ramps? You are working too hard. Just slide under there and do it as it sets. It's a little close, but OK. A sheet of cardboard on the floor and it's easy to slide under. It catches the drips or spills too.
Ramps take about 20 seconds to drive up on and they make it super simple to remove the skid-plate (you can swing it down and off) which ultimately makes it super simple to change the oil. ;-)
