LittleCaesar
Ok, the IAC (idle air controller) is located under the throttle body. It is attached with four soft brass screws. There is a gasket that goes between the IAC and the throttle body so you may need a new one before reinstalling. Make sure to dutifully take note of how the coolant and vacuum lines attach. Use the search engine to find out a better write up on such.
IMHO, if you had new 02 sensors your fuel trims would probably register quicker and more accurate than at the moment but don’t think it is your problem.
Nope, the TPS seems to be reading correctly. With the butterfly closed the sensor should read about 9. That is why the value of 8 for your MAF at idle is something to make note of.
Good luck.....
Good luck.....
