SPC4Runnergirl
I have a 2005 4Runner limited that had been running rough lately then check engine light came on along with the VSC track and the slip indicator light those came on in the past but it had always been a loose gas cap but this time I ran a scanner on it because of how the vehicle had been running I used a fixed scanner and it produced a po306 code misfire cylinder 6 here are the freeze frame data from that date of January 13th when I first ran it.
I decided to let my friend who knows a little bit about cars install a new spark plug just to see if that was the cause of it but he installed a new spark plug in cylinder 5 instead of cylinder 6 because that's where he thought it was so after he was done it wasn't until then that I realized when the code came back up that he installed it in the wrong cylinder but I rescanned the vehicle with a different scanner an actron one and it came back with the same cylinder 6 misfire code along with po305 cylinder 6 misfire and an additional po30 multiple cylinder misfire code so what I am wondering is did he install the spark plug wrong for the cylinder 5 code to come up now being that's what he just replaced I'm just so confused and I don't want him to mess up my car can anyone shed some light also this is the freeze frame data from the actron scan results on February the 2nd the other day when I did it thank you guys y'all are great I love this website
I forgot to add that the check engine light is on and flashing the VSC track light is on and the slip indicator light is on along with those codes.
I'm mainly concerned with why after putting a new spark plug in cylinder 5 (on accident it was supposed to go in number 6) why I'm getting a misfire code for that cylinder now as well as for 6 and now a random multiple misfire code.
