stir_fry_boy
You can't usually tell if your canister is bad by looking at it, unless it was obviously damaged. Did you replace the gas cap?
Yeah, gas cap is okay. Like I said its holding vacuuming. so there can't be a leak.
I am trying to say the valve in the rear is gone, look at first pic, its a block of rust. I am going to try and run it off a 9v battery if that doesnt work, then off to mechanic land to be replaced.
These are not difficult to replace at all. Toyota Rust Penetrant is the best out there for this stuff. The valve itself is plastic inside, the metal is just the bracket that holds it in.
Just received the new valve, I couldn't tell where things were until I saw the new valve. pretty sure the mount here is gone. But we shall see.
The more I think about it I am thinking its the charcoal canister. My dad mentioned he toped it off so many times. till the point where he saw the fuel. so pretty sure its gone. Hoping mechanic tells me other wise when I bring it in early next week.
I agree I'm sure it is easy to replace, just quiet busy with a few things at the moment, and I would like to keep him in the loop if it is indeed the canister. I dunno if it make sense, but I have been over thinking this check engine light for too long. Just want it to go away.
I had these 3 codes, [P0440, P0441, P0442], when I first bought my truck.
After replacing the VSV at the canister & replacing the gaskets on top of the fuel tank, it ended up needing the canister.
Those codes on my truck took 500 miles + to come back when I was trying to fix it. I ended up taking it to the dealership, and they couldn't pinpoint the problem.
What you can do to make sure that the top of the gas tank isn't leaking is to squirt some soapy water on the top and see if it bubbles, if it doesn't it rules out one of the plastic openings being broken at the top of the tank.
My isolated P0441 code was fixed with a second-hand purge valve. Resolved immediately and forever.
Did you do the 9v battery test before replacing the VSV on the canister?
Did you just partially lower the gas tank to replace the overfill check valve gasket on top of the gas tank or did you remove the gas tank completely to do it?
I know it's been a while but when you replaced the VSV and overfill check valve gasket, do you remember if the same codes came back or if it was a different code?
After removing the gas tank skid, did you have to disconnect anything else (hoses, other lines, etc.) to lower the gas tank in order to squirt soapy water around the overfill check valve?
How did you go about pressurizing the gas tank to see if the overfill check valve gasket was leaking to see the air bubbles in the soap? Hand held pump?
which valve is that??
purge valve? the one that opens the canister to the throttle body hook up?
This valve did not click, it was dead. I don't think its a valve anymore. Well I am throwing it in the fire pit this weekend to celebrate. Doesn't mean that there isn't more wrong with the evap system, but certainly one big problem here... Hopefully this blasted code doesn't come back on. fingers crossed!
went from 1/8 full to full, and filling gas still got stuck, but could be filler neck also F'ed since it is so rusted.
Thanks.
edit holy hell, huge image size.
