[MENTION=28464]eimkeith[/MENTION] -- Sorry for my questions this isn't quite clear to me. What are the middle set of holes for, I see metal behind them?
The middle holes are the one inch drop to compensate for a 3 inch lift, the lower holes are a two inch drop for 4 inch lift, used in conjunction with the PLB.
So, my thinking is: worst case scenario is a 4 inch lift situation, where you will now have raised the axle end of the panhard by 2 inches, and lowered the frame mount by two inches, and maintained the roll center while correcting everything else. Correspondingly, as the height of the lift decreases, the roll center benefit increases. You guys agree?
There will be minor clearancing of the factory bracket at the one inch holes (a few millimeters of metal - the photo is misleading.)
All 3 sets of holes should still be usable with the bracket installed.
Also, since your design seems to angle straight down as opposed to the commercial one that follows the angle right contour of the factory piece, does yours help take out some of the shift right of the axle? Is that the intention?
Yes, straight down to center the axle.
I'm not sure why the commercial one would angle at all, using a drop should allow the axle to properly center using the stock panhard bar - so the holes should be in vertical alignment with the factory hole, to my thinking.
Perhaps the commercial drop is attempting to move the driveshaft away from the tank? - but that shouldn't be an issue if the panhard is horizontal at rest and is stock length...?
:shrug:
