vicpick58
First I want to state that this post in mostly intended for those that are checking this forum doing research into buying a 5th gen T4R.
When I was at that stage in my research, I almost ruled out the 4Runner after reading about the oil change. So let me say I am not going to go into details of procedure or tools required, that has been discussed in great detail in other posts.
I just want to say that the oil change procedure is NOT difficult. It DOES take a little longer than usual due to the extra steps involved, but nothing to worry about if you have a good set of metric sockets and the correct oil filter wrench. And frankly if you normally perform your own service, you probably already have what you need with the possible exception of the size filter wrench which I purchased at the Toyota dealer when I bought the oil and filter.
I did this first oil change at 4967 miles and just under 5 weeks of ownership of my TE. I did notice a few small metal particles in the bottom of the filter canister so I made sure I cleaned it out real good with some gasoline. I also noticed the drain oil was a little dark in color, but I know that does not necessarily mean anything.
I also greased the zerk fittings on the driveshafts, this is very easy to do too while the vehicle is up on the jack stands for the oil change.
As a side note I installed an AVS bugshield while I was working on the vehicle it seems to fit very well and was easy to install with out any need for drilling.
And for anyone that cares, I already took a pretty good hit in the windshield and need a replacement, cost is right around $500 for an aftermarket one from my windshield guy that I have done business with for years.
