PIAA Xtreme white bulb questions
Falls
Super Moderator
Has anyone replace their lo/hi and fogs with these . I think the lo and fog are H11 , but but not sure about the hi's . (I have to look)
This will be an expensive upgrade for all 6 bulbs . Is it worth it ????
How is longevity of the bulbs ?
Any problems with to much heat ?? wiring ?? lenses ??
They would be going in my 11 TE.
I do offf road and do live out in the country , so it is dark.
yes I did search. Looking for updated results on new and old users .
Thank you , but the link didnt work. I am also asking specific 5th gen owners if they have had issues with these lights . Thank you .
So sorry... in the future I'll be more careful in offering what I think could be a useful information source. My bad.
I have used these bulbs in other trucks. They are brighter than stock just like the Silverstar Ultras that I am using in my 4runner. The problem with any of these "higher intensity" bulbs is that they don't usually last as long as standard bulbs. Sometimes you might not get a year's worth of use out of them before they burn out. They do make a difference in visibility though.
I know, what were you thinking?!?! :naughty: The Sylvania Commercial thread was a good read, I was wondering about them.
I think he meant he wants a 5th Gen owners experience with these lights. Meaning he didn't think he would find that population on HIDPlanet's forum.
This guy has been nothing but pleasant in all his posts, not sure why his comments are being interpreted as otherwise.
I can't speak for these lights in a 5th Gen, but agree that in other vehicles you typically don't get the longevity like stock bulbs. Haven't had a problem with them as far as increased temperature effecting lenses or wiring either.
I had the PIAA Xtremes whites in my 5th Gen before I did the S2K HID projector retrofit. The PIAA's Xtreme Whites seemed brighter to me but not so sure after another review I read.They have the blue tip and that makes the light a bluer/whiter color which appears brighter but is really not.I wouldn't buy them again unless I found them cheap as stock ones.
Here's the review by Chuck on his 2010 TE, just click on the PIAA review.... 2010 4Runner Trail Edition
Now on the subject of the high beams in which ours takes the 9005 bulbs. I recently put in HIR 9011's and there is a big improvement in those. You have to modify the HIR bulb base but it's really easy to do.
Here's the write-up and where I bought those...... HIR Headlights 9011 9012 bulbs
I agree with Harper 100%...I have them in my ride and while the light is a different color, they are no brighter and do nothing more visibility wise. I should have saved the money and put it towards a retro-fit.
Also - I have the plasma yellow fogs...decent, not as good as when I've put them in my other vehicles though.
Exactly what I wanted to know was 5th gen specific . Thank you dispence.
4shorerunner , that is good money saving news. Thank you sir.
H11 to H9 conversion...cheap upgrade and well worth it
I have been using H9s for the low beams and HIR 9011 for the high beams since December. The H9s are a huge improvement over the H11s. I was worried about overheating due to the higher wattage 65w vs 55w, but so far no problems at all.
The H9's produce 2100 lumens vs the H11's 1350 lumens, so you are getting a much whiter and brighter light. I aimed my headlights slightly down so that I don't blind other drivers and I have NEVER been flashed (yet).
You can order the HIRs from Candlepowerinc.com or amazon.
For the H9's I just picked up the cheapest Osram/Sylvania's that I could find. Then you have to make a slight modification to the base in order for it to fit. Just look at the H11s and use some clippers or a dremel to make the H9 tabs look the same. Here is are some links:
Daniel Stern Lighting Consultancy and Supply
http://www.toyota-4runner.org/5th-gen-t4rs/76192-sylvania-silver-star-lumnics-yellow-fogs-2.html
I highly recommend this mod.
-enduro
Silverstar Ultra bulbs are definitely brighter than the stock bulbs in a 5th gen. and they are not "blue" like some of the other brands. They are not cheap (40 or 50 bucks/pair) . I may end up with some sort of HID retrofit eventually. You will see an improvement with the Silverstars, but it may be a better idea to switch to HID and avoid the shortlived not as bright as HID replacement bulbs.
-enduro
Enduro beat me to it. Save your money on the Piaa's and switch out to the H9's. I am running them in both low's and fog's and also have the HIR's in the high's. The combination is seriously ridiculous. They make any other bulb modification or switch a complete let down. Trust me, I spent 12 hours and a coupe hundred dollars adding Piaa 510 yellow fogs into the lower grill and they can NOT be seen when I switch them on as the H9's in the low beams and fogs drown them out.
For the fogs - These look just like HID, plug/play, less wattage and should last the life of the vehicle.
V-LEDS HID 5K WHITE 28 LED 13W FOG LIGHT BULBS H11
Koz
Maybe they may look like HID's as in they are whiter light then Halogen.
After that ,talk about oranges to apples.
These are 400 lumens? And I think they say combined 400l.Maybe they would make good marker lights but they don't have the output for fogs.
Halogens are 1200-1600 lumens
HID's are 2800+ lumens
HID's last 2000+ hours or 4 times longer then Halogen bulbs.
Don't get me wrong about LED's....Rigid Industries and VisionX have out great LED lighting products and LED's have come along way in a short time.They both have light bars putting out close to 20,000 lumens and they both are coming out with newer ones.
These V-LEDS are not in the same league though . Matter of fact they are'nt even in the same universe!
That's 400 lumens per bulb, 28 combined LEDs per bulb. You are correct about halogen and HID producing more light (lumens) but the VLEDs are nowhere near a marker light. I can not explain why they look so bright, but they do. I disconnected the headlights and lit only the fogs and the VLEDs lit better (fog pattern, and temp.) then the OEM halogen. They look just like Silverstars (brightness) but a little higher temp (OEM HID, 4300K). I have HID headlamps and the H11 VLEDs are a perfect match. Also they are plug'n'play and a LIFETIME bulb. I'm SICK of replacing fog light bulbs (and the cost)!
This is a bad cell phone pic but you can see the temp and brightness.
Koz
Some other LEDs pics.
-enduro
Great thinking . I did that years ago on one of my other trucks and never gave it another thought.
Are you using just a reg halogen H9 bulb ? that would be a nice upgrade for fogs and for lo beams . I'll try to pick some up tomorrow. I do not know what Osram/Sylvania are . Is that the Silverstar ? or SilverStar Ultra or just a regular halogen bulb ??
