Pinch Welds... Cut or Bend?
Bfh
After a year and a half of rubbing at full lock and articulation, I decided to take the leap on my 4runner and do the "BFH Mod". I cut a bunch of sheet metal and plastic and did the big "SMASH!, SMASH!, SMASH!" on the pinch welds. I decided to bend the welds outward into the recess to maximize the space. I covered the entire bent over pinch weld with 3M seam sealer and then sprayed 3M rubberized undercoating. I gained a ton of space and can finally take advantage of my BMC. I feel like I can make the jump from my 195/70/R17 Toyo M/T's to 185/75/R17 without much issue. Time to test.
Very clean looking. Going to get on the 3M coating for the whole area!
For the seam sealer that you used. Was it brush on, or from a tube?
To get 37's to fit my 4th gen I ground off the pinch weld, and bashed in the remaining firewall metal since it wasn't being supported by the pinch weld seam anymore. Maybe close to 1/2" gained.
Tacked a plate over top:
Sealed the seams:
Painted black:
piggybacking of what [MENTION=216416]Mutant138[/MENTION] did to remount the fender, but didn't want to drill into the body, as the main reason I'm here right now is to silicone pinch weld seams to mitigate a cabin leak due to my shoddy pinch weld work.
may be helpful to those needing to cut off their fender mounts. currently running 34's on -10 SCS wheels, but I imagine I could clear 35's now with minimal amount of work needed.
PRWhite
