Please recommend OBD scanner
dcjeeper
I need a scanner for my '16 SR5 and '17 Tacoma general diagnosis but also to check the transmission temperature. Anyone can recommend a good one for Toyotas?
Strangely enough my new Kenwood receiver pulls codes and can even reset them.
Also can create gauges for info you want to pull like intake temp. Even tire temp and pressure.
Another vote for OBD2 MX+. Pulls codes on ‘12 Limited, tried to use to relearn new TPMS sensors with Carista but Carista just doesn’t do it.
The ODB2 MX+ has tons of app support and was able to pull and reset all the codes I needed.
A third vote for the OBD Link MX+.
You can also look at transmission pan and torque converter transmission fluid temp with this device. Required for transmission fluid change.
I also use a OBD Link MX+, it is worth the higher price.
"Torque" App shows transmission pan and torque converter transmission fluid temp, gear / torque converter lockup etc.
Only for reading the TPMS i have to use an other App "OBDLink".
I use the ScanGauge 3 - All New Touch Screen OBD2 Code Reader
Super happy tith this toy,
Great for measuring temperatures and setting alarms for overheating
Which PID did you use. I have 2017 and couldn’t locate the A/T temperature PID.
I like the Scanguage 2. It is attached all the time. Gives 4 display readings.
It mounts out of the way with supplied velcro on top of steering column. Custom X guages can be programed.
I use it for tranny temp in mountains on hot days . I bought a second cable so I can connect it to other vehicles and leave my mounting cable zip tied under dash on my SR5.
I can see all 4 tire temps at a glance to catch a tire issue before it becomes dangerous, especially roadways with no lanes to move into out of traffic lanes. Or highways with steep shoulders and ditches.
Cannot load pics today.
Code:
TXD		RXF		RXD	MTH		Name	Notes
07E02182	046105820000	2808	00090005FFD8	TFT	Pan (fluid)
07E02182	046105820000	3808	00090005FFD8	TCT	Converter
tuṣṭāva
